Old 08-11-2010, 11:29 AM   #76
Suspended
Trader Rating: 86 (100%+)
just finished assemble my new x10 using team wave rb50 with 13.5t motor and 2cell lipo, jayco purple front and back tires
just tried it on tennis court and it runs fine except gears make funny noise and vibrate at low speed. may need to redo the center shock
i like how the car drive and it handles but it still need some fine tuning to make it run properly
will try again on track this friday
littlealex is offline   Reply With Quote
Old 08-11-2010, 11:42 AM   #77
DekelzMan's Avatar
Hey Alex,
Looks good! So are you planing on running it at the RRR Trophy race Sept 4-5th? Sounds like we're bringing 10 or 12 Pro10 cars
Mick
DekelzMan is offline   Reply With Quote
Old 08-11-2010, 10:59 PM   #78
Suspended
yes, of course i would like to join the race if i can get a day off from work.
but i dont have 1s battery or 10.5t motor, i dont know what class i will be running
Old 08-11-2010, 11:06 PM   #79
DekelzMan's Avatar
We run 2S LiPos, not 1S so you're good that way. Some of our guys run 13.5 as well as they can't handle the power. It would be good experience for you!
Come on
Old 08-11-2010, 11:46 PM   #80
Suspended
did you mean i still can race with 2 cell and 13.5? cool, any body limit? do i have to make my body wider?
Old 08-12-2010, 07:05 AM   #81
ElliotCanada
John, How about battery placement for a 1s pack? A friend placed his battery up front with the speeder tucked behind it like a CRC car. Also what do you start your tires at?
thanks
chuck
mackin is offline   Reply With Quote
Old 08-12-2010, 08:05 AM   #82
Talking
Chuck
I have my Battery at the Front with the Tekin behind it on my WGT. See attached. I start my CRC Spec tires at about 56mm Front and Rear - Big fronts but I don't want to grind them down for Club Racing. We are running 17.5 Single. You'll probably will want about 55mm fronts to start for 13.5. That's where I start for my 2 Cell 25.5 Xray.
XRAY X10 Link-wgtxrayesc.jpg   XRAY X10 Link-wgtxraychassis.jpg   XRAY X10 Link-wgtxraysophia.jpg
Number 49 Lou's Speedway Canada, Honda House www.hondahouse.com
ElliotCanada is offline   Reply With Quote
Old 08-12-2010, 09:46 AM   #83
DekelzMan's Avatar
Hey Alex,
No, you definitely don't NEED to run a wider body unless you've widened the chassis as well. There are several cars that run narrow (200mm) in our club with great success. Some will be at the race in Richmond.
Old 08-12-2010, 10:48 AM   #84
Thanks John, I really appreciate it.
chuck
Old 08-12-2010, 11:46 AM   #85
Suspended
cool, looking forward to meet you on the track again
btw how should i shim the front end and rear hubs on medium traction treated asphalt?
i will use purple front and pink rear as you recommended as soon as my purples are done
Old 08-12-2010, 12:10 PM   #86
DekelzMan's Avatar
By shim, do you mean for ride height? Our track is fairly smooth so I set my ride height to 4mm in the front and 3mm in the rear. I have no idea what the RRR track is like so at the moment your guess is as good as mine
See you there!
Mick
Old 08-16-2010, 07:25 AM   #87
Ran the new car at The Gate on Sun worked well right out of the box. 1s battery pack up front as in John's pics. Would like to stiffen up the rear shock with a heavier rear spring or CRC shock and springs. John what is the CRC shock you are using? Need the car to be able to roll through the corners a little better.
chuck
Old 08-25-2010, 07:26 AM   #88
It's really nice to see such an interest in this car. Hopefully after Vegas there will be more info posted.
chuck
Old 08-25-2010, 08:38 AM   #89
tudor_47's Avatar
I found out by trying that it is NOT possible to run 48Pitch 92T spur in the car.
There is simply not enough space left between motor and spur, 1mm from edge of spur to motor axle.
anyone oout there running 48pitch? if so what gearing are you using?
I have a 5,5T motor...
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 08-25-2010, 10:57 AM   #90
Talking
I use the CRC 3290 Bladder Shock
Xray announced they will soon have XRAY X10 Link Setup Sheets so we can post our setups.
Horsham Rc Carpet racing 2009 Jeff Cuffs Racing Forum 3890 09-12-2010 02:01 PM
Xray X10 World GT Car PitNamedGordie Electric On-Road 262 04-22-2010 03:18 AM
Three xray cars to be released at Nurnberg hobby show. ????? rx7ttlm Nitro On-Road 44 02-04-2010 02:06 PM
Custom Model Cars Zoidberg Australian Racing 224 09-04-2009 07:10 AM
