Old 05-12-2010, 05:17 PM   #16
bjholz's Avatar
That thing looks like a mean machine. Are DD cars coming back in popularity?
www.trackside.com
FT SC10, FT B4, FT T4, b44.1
Tekin, Ace, Airtronics, Sav÷x, Novak, Murfdogg, LRP
bjholz is offline   Reply With Quote
Old 05-14-2010, 11:56 AM   #17
Talking
There are at least 4 of the new Xray X10s being prepared for SCAR Racing in Canada. The first shipment to arrive at Lou's Speedway SOLD OUT fast. Another shipment is scheduled to arrive on Tuesday but some are spoken for.
More SCAR information can be found at www.londonrc.com
SCAR 25.5 runs the Orion 2400 LIPO 2 Cell so the XRAY X10 is another great choice along with the CRC GenX10. Currently about 95% of the cars are CRC but the Xray X10s are becoming popular as well.
Xray needs to make a Wide Rear Brace with a selection of Body Mount Holes so Shorter Body Posts can be run.
Also a selection of stiffer Centre Shock Springs are needed ASAP.
ElliotCanada is offline   Reply With Quote
Old 05-20-2010, 01:37 PM   #18
Been looking at the lack of rear springs and the Associated 12r5 looks to run a similar sping's on the side's so i have ordered some can anyone measure the center spring internal diameter and length?
Speedy Steve is offline   Reply With Quote
Old 05-20-2010, 01:42 PM   #19
The CRC Side Springs work.
Old 05-22-2010, 05:37 PM   #20
DekelzMan's Avatar
I started campaigning the X10 Link a couple of weeks ago in my club's Pro10 class which allows 2 cell LiPo and 10.5 Brushless with GTP bodies. The bulk of the club runs 235mm cars as did I until this season. We have been contemplating running World GT for 2011 so I thought I'd try a new car for this season and start to get my feet wet with the new width cars.
As the car was designed for World GT I expected to make a few modifications as the weight and horsepower were quite different. Since XRAY has not yet released a selection of tuning options for the shocks and front springs, I opted to replace the shock with an HPI/Windtunnel Combo: http://www.windtunnelracingproducts....c35c8dc457ad45
The shock is longer than the stock unit so I needed to make some mods to the front ball location. Since I was not planning to run an antenna on the car I had the entire shock mount plate to play with. I drilled a few extra holes that would allow me to adjust the length for droop independently of the spring collar to allow real fine tuning options.
For the front springs I have prepped up a set of arms with long kingpins and a host of windtunnel springs but so far I have been running the stock Xray kingpins and stock springs.
Fully loaded, with body on, the car came in at 1008 grams so I had to add almost 200 gms to get it up to 1200 which is our class spec weight! I added some titanium plates to the battery slots in the chassis plus I added a few stick on lead weights just in front of the receiver to balance out the car left to right.
There is VERY little choice when it comes to GTP bodies for 200mm cars but our club managed to source out a body from ABC called the "Responce" and it seems to be working pretty well so far.
In the two weeks I've run the car I'm very happy to say it has pretty much dominated the field, even against the wider cars! The weather has been very changeable and we've had cool and windy and hot and sunny, and the car has worked equally well in both situations. The weather is supposed be questionable tomorrow as well but I'll report back with any new info.
I won't be racing next week so I'll have time to tackle Phase 2 which will be to turn this beast into a 235mm car where I'll have more selection of bodies to play with...
Mick
DekelzMan is offline   Reply With Quote
Old 05-22-2010, 08:37 PM   #21
Talking
The Honda House Prelude SCAR 25.5 Xray X10 Link is ready for testing. SCAR runs 1030 Gram Minimum Weight, HPI 4 Passenger Bodies, Novak 25.5 Brushless Motor, Havoc 2S Sport ESC, Orion 2400 LIPO 2 Cell, WGT Spec Tires.
XRAY X10 Link-xraychassiscomplete.jpg   XRAY X10 Link-xrayfranken.jpg   XRAY X10 Link-xraypreludetop.jpg
Old 06-07-2010, 03:42 PM   #22
tudor_47's Avatar
Mick
HI!
what gearing and pitch are you using?
What parts will you be using to convert it into a 235mm car?
Thanks!
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 06-07-2010, 03:44 PM   #23
tudor_47's Avatar
Hi
I see that you have widened the rear body post fastener... what are the parts used to accomplish this?
Thanks!
Old 06-07-2010, 03:51 PM   #24
RC MARKET's Avatar
Nice photo !
X10 Link have conv. kit to 235mm ?
RC MARKET is offline   Reply With Quote
Old 06-07-2010, 03:51 PM   #25
tudor_47's Avatar
Default first track outing with my X10
Hi
tonight I got my X10 link out on track for the first time.
As it was the first time I hade a few things coming loose such as the left rear axle clamp. When this happened the spur got beaten some... and after a few morre minutes I totally cleaned of all the tooth from my spur.
Back in the pits I noticed that my side damper was loose to!
So remember to tighten everything properly!
I now need to replace my spur and attach the damper (properly) and go through the rest of the screws for loose screws.......
so a 5 minute outing..a new record?
/Johnny
PS
any ideas as to what gearing I should shoose for a 5,5T brushless???
48P
64P
the straight is approx 30meters?
Old 06-07-2010, 04:58 PM   #26
Talking
I modified the CRC GenX10 optional Wide Body Mounts to fit the Xray X10 Link.
http://www.teamcrc.com/crc/modules.p...prodID=7719033
Number 49 Lou's Speedway Canada, Honda House www.hondahouse.com
Old 06-09-2010, 08:58 AM   #27
FOXY923's Avatar
The lack of response from Xray with respect to this car is very disheartening. They've designed a great car, now they need to get some options out like springs and a wide body mount. Every other car they make has pages of option parts why not this car?
Paris Junction Hobbies ~ RROL.ca ~ Lou's Speedway ~ SCAR
XRAY X10 Link ~ CVTA Sakura Zero S ~ XRAY X10 Custom Oval ~ Caster Fusion F18
RACE 4FUN
FOXY923 is offline   Reply With Quote
Old 06-09-2010, 10:28 PM   #28
Talking
Xray X10 Link smashes both SCAR 25.5 Track records last night at Lou's Speedway. 200 Pan Car was the largest class.
Old 06-16-2010, 01:26 PM   #29
Talking
Seven Xray X10 Link Cars have been Sold in this area (London Ontario Canada) and will be running at Lou's Speedway. Will this be the largest gathering of XRAY X10 Link cars in North America, to date?? Perhaps.
We're racing again tonight against a field of CRC GenX10 Cars.
Trying new setups tonight as well as sharing setups with the other Xrays.
Old 06-17-2010, 11:56 AM   #30
Here are the Best Runs to Date at Lou's Speedway in Canada in the SCAR 25.5 / World Gt 17.5 Single Eight Minute Challenge Races
Best Laps
1 John Elliot XRAY Prelude 11.092 Track Record
2 Lou Vanderwey CRC WGT 17.5 11.174 Track Record
3 Ed Lacika CRC Porsche 11.200
4 Kevin Hill CRC Toyota 11.210
5 Ryan Fox XRAY Eclipse 11.227
6 Jay Devost CRC Prelude 11.230
7 Mario Biscaro CRC Camaro 11.303
8 Steve Pascoe XRAY Prelude 11.319
9 Bart Garner CRC Dodge 11.402
10 Dave Dwyer XRAY Nissan 11.557
11 Scott Stuart CRC Supra 11.591
12 John Watkins CRC Prelude 11.757
13 Dan Engelbreth CRC WGT 17.5 11.773
14 Chris Hewitt CRC 11.857
15 Richard Garner CRC Stratus 11.990
16 Gervais Grant XRAY WGT 12.209
Best 8 Minute Runs
1 John Elliot XRAY Prelude 42 8.04613 Track Record
2 Ed Lacika CRC Porsche 42 8.04822
3 Kevin Hill CRC Mazda 42 8.11831
4 Lou Vanderwey WGT Sophia 41 8.00473 Track Record
5 Ryan Fox XRAY Eclipse 41 8.00837
6 Mario Biscaro CRC Camaro 41 8.07366
7 Jay Devost CRC Prelude 41 8.09199
8 Steve Pascoe XRAY Prelude 40 8.01340
9 Bart Garner CRC Stratus 40 8.02169
10 Dave Dwyer XRAY Eclipse 40 8.08685
11 Scott Stuart CRC Supra 40 8.11789
12 Chris Hewitt CRC 39 8.03640
13 John Watkins CRC Prelude 39 8.04126
14 Dan Engelbreth CRC WGT 39 8.09191
15 Gervais Grant XRAY WGT 38 8.06906
16 Richard Garner CRC Stratus 38 8.12221
Average Laps
1 John Elliot XRAY Prelude 11.54
2 Ed Lacika CRC Porsche 11.54
3 Kevin Hill CRC Mazda 11.71
4 Lou Vanderwey WGT Sophia 11.72
5 Ryan Fox XRAY Eclipse 11.73
6 Mario Biscaro CRC Camaro 11.89
7 Jay Devost CRC Prelude 11.93
8 Steve Pascoe XRAY Prelude 12.03
9 Bart Garner CRC Stratus 12.05
10 Dave Dwyer XRAY Eclipse 12.22
11 Scott Stuart CRC Supra 12.29
12 Chris Hewitt CRC 39 12.40
13 John Watkins CRC Prelude 12.41
14 Dan Engelbreth CRC WGT 39 12.54
15 Gervais Grant XRAY WGT 12.81
16 Richard Garner CRC Stratus 12.95
The Xray X10 Drivers are working on setups and sharing information in order to compete with the tough CRC GenX10 Competition.
Horsham Rc Carpet racing 2009 Jeff Cuffs Racing Forum 3890 09-12-2010 02:01 PM
Xray X10 World GT Car PitNamedGordie Electric On-Road 262 04-22-2010 03:18 AM
Three xray cars to be released at Nurnberg hobby show. ????? rx7ttlm Nitro On-Road 44 02-04-2010 02:06 PM
Custom Model Cars Zoidberg Australian Racing 224 09-04-2009 07:10 AM
