Old 03-04-2012, 06:40 AM   #181
FOXY923's Avatar
Originally Posted by colin storey View Post
Has any one succesfully reglued the threaded part back into the graphite axle.
colin
I never got the threaded part out where the axle was in any condition to have it glued back in
Use a CRC axle if your breaking the Xray axles. You need to use extra bearings or shims for the diff but it works. Or you can get the CRC hubs as well.
Paris Junction Hobbies ~ RROL.ca ~ Lou's Speedway ~ SCAR
XRAY X10 Link ~ CVTA Sakura Zero S ~ XRAY X10 Custom Oval ~ Caster Fusion F18
RACE 4FUN
FOXY923 is offline   Reply With Quote
Old 03-05-2012, 01:49 AM   #182
I havent had it long enough to break one.I just couldnt get the diff to tighten and that was the reason.Even melted a spur as it was too loose.I just want to reglue it as a spare.
colin
colin storey is offline   Reply With Quote
Old 03-05-2012, 07:22 AM   #183
FOXY923's Avatar
colin
Were you able to get the bearings off the axle after this happened? I've never been able to do that with out destroying the axle For me, once the threaded portion came unglued it expanded the axle and actually split the end. This happened 3 times.
If you can re-glue it let us know how it goes.
RACE 4FUN
Old 03-05-2012, 08:50 AM   #184
Rich Panganiban's Avatar
Trader Rating: 72 (100%+)
New to WGT, and have a couple of questions.
What size motor do you run in the WGT class? 13.5 or 17.5?
Who makes a race spec 1s compatible esc?
Thanks for the help!
Rich Panganiban is offline   Reply With Quote
Old 03-10-2012, 02:53 AM   #185
Yea thanks for that.After close inspection the axle was cracked.
colin
Old 03-12-2012, 02:15 PM   #186
Halloween's Avatar
For indoor we drive 17.5T 2s lipo or 10.5T 1s lipo.
Outdoor we drive 10.5T 2s lipo (100+ km/h...). But often the club (drivers) decide which motor will be run during a race.
Hobbywing has a great 1s 120a esc on the market. You can use this one also for 2s lipo's
Halewijn
l========l
['..] '' [..'] XRAY X1012 Link Wide Ed. 235mm - www.machheemstede.nl -XRAY X10 Link Rain Ed. 200mm
Halloween is offline   Reply With Quote
Old 03-12-2012, 02:33 PM   #187
Halloween's Avatar
Or you can use the new steel axle XRAY 375012. I do and they are great!
Halewijn
l========l
Old 03-12-2012, 10:06 PM   #188
Halewijn
Thank you.
Old 03-17-2012, 07:06 PM   #189
Default Servo for 10.5T outdoor
New to WGT, just picked up a roller. Will run outdoor 10.5T 2S lipo. What do people like for a metal gear, fast, good torque servo that fits?
- David Gillis
RACE TECH HOBBIES (Where the racers shop)
XRAY T3 2012
David G is offline   Reply With Quote
Old 03-23-2012, 02:07 AM   #190
Halloween's Avatar
Hi David,
you must use a low profile servo.
The Futaba 9551 ore savox 1251 are the one i use.
Don't forget to put 1.5mm shim below the servo mountpost. ortherwise the servo don't fit.
Have fun with the x10!
Halewijn
l========l
Old 03-23-2012, 03:56 AM   #191
tudor_47's Avatar
I'm running a 1:12 servo from spektrum
I think it is called the H5000
I drive outdoors on large asphalt track
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 03-24-2012, 12:04 AM   #192
i just built one of these cars.
It has a steel tube rear axle out of the box...maybe they have changed cause it sounds like may have been graphite before.
I have not taken it to race track yet but the kit, like other xray stuff is top quality, way better than my previous pan car.
The only thing that doesnt seem quite right (although not a problem) is the range of adjustment for height of the rear axle. I have to use the +2 inserts (lowest ride height) with worn set of tires and would never use any of the other inserts.
jeff_78 is offline   Reply With Quote
Old 03-24-2012, 04:27 PM   #193
Halloween's Avatar
Hi Jeff,
Xray makes good quality! It is one big party to build one out of the box
They change the graphite rear axle for the steel one. I tried both and i'm very happy with the new steel one.
The X10 is een large X11. Unfortunatly XRAY have't though about the ride height of the tires of the X10. That is why I bought the ride height from CRC. These one are from 0 till 3.5mm The tires out of the box are 63mm. Your ride height will be 8.5mm. That's a little bit too height, so you can make the tire smaller to 61mm. Ore you don't mined for a practice and drive till they are on the right ride height for the race. That's what i do. I drive 1 ore two times and then they are oke.
Good luck with your X10 and keep posting!
Halewijn
l========l
Old 03-28-2012, 10:29 PM   #194
yeah well i gave it a run on carpet, starting with base setup. with a couple of changes got it handling spot on.
First thing was the preload on the centre shock spring (base setup sheet: 5mm) I reduced this to almost none so there was a slight droop on rear pod when lifted off the ground. I added some spacers to raise the hight of the rear ball end of the shock to make it a little harder as i do not have any harder springs to use. Ideally i want a harder spring and probably thicker oil too for centre shock.
Then i added a little more caster. I played with front track width but default (no spacers) was best.
Its a very solid and consistent car i had alot of fun driving it as it went exactly were i wanted it thru cormers. I run a 2 cell shorty pack and 10.5T so its very quick and light. Asphalt next!
Old 03-31-2012, 02:11 AM   #195
ok i've now got mine running. I was just after some information on tyres. I have Dbl pink and other colour tyres. What i want to know is the different shore ratings and the different manufacturers comparisons.
Like what shore rating is the dbl pink wheels.
colin
Horsham Rc Carpet racing 2009 Jeff Cuffs Racing Forum 3890 09-12-2010 02:01 PM
Xray X10 World GT Car PitNamedGordie Electric On-Road 262 04-22-2010 03:18 AM
Three xray cars to be released at Nurnberg hobby show. ????? rx7ttlm Nitro On-Road 44 02-04-2010 02:06 PM
Custom Model Cars Zoidberg Australian Racing 224 09-04-2009 07:10 AM
