ProtoForm Mazda 6 Body >
Old 03-27-2004, 11:55 AM
wolfeman09's Avatar
Default ProtoForm Mazda 6 Body
I just got the Mazda 6 body and I realized I can mount the wing in two positions on the body. I can mount it more to the front or more towards the rear.
What are the benifits and disadvantages of both?
What is everyone mounting the wing?
Thanks...
wolfeman09 is offline
Old 03-27-2004, 12:17 PM
grim's Avatar
i dont know an anwser but i just bought the same body and if you want a template let me know ...
my guess on the wing would be that the more to the rear its mounted the more down force your going to get .
grim is offline
Old 03-27-2004, 12:19 PM
JDXray's Avatar
I have had my Mazada 6 body for 2-3 weeks now, excellent body top would recommend it to anyone. I mounted my rear wing in the back. I tried it in the front and it didnt make much difference. I am not sure either which is better, but in my opinion i have to say in the rear.
JDXray is offline
Old 03-27-2004, 01:22 PM
Default Re: ProtoForm Mazda 6 Body
Thanks...
more to the front gives more front grip and to the back gives more rear grip.
trf racer is offline
Old 03-27-2004, 08:08 PM
JimmyMac's Avatar
I just posted that pic in the 415 forum, but you can see where I mounted my wing.
To me, this body has alittle less steering goin into a turn than the Alfa 2.0 with this setup. I'll do more comparisons of the 2 next weekend. But I like the body soo far. Seems pretty stable.
JimmyMac is offline
Old 03-27-2004, 10:54 PM
Speedo's Avatar
In theory you get more traction with the wing mounted back. The reason behind this is that the further back the wing is, the "cleaner" the air is that it gets, so it can produce more downforce. By clean I mean that the air coming off the body is turbulant - not so "clean".
Speedo is offline
Old 03-27-2004, 11:43 PM
Neil Rabara's Avatar
I recommend mounting the rear wing as far back as possible without breaking the plane of the rear bumper. As I remember ROAR rules, the wing cannot exceed the height of the roof, and rear bumper. If it's for club racing, do what ever you want.
Neil Rabara is offline
Old 03-28-2004, 12:07 AM
Default How about the holes on wing
Hi,
How about the openning holes on the wing ?
Anyone try cutting out the openning ? what's the characteristics ?
ongbenghui is offline
Old 03-28-2004, 10:16 AM
fatdoggy's Avatar
ongbenghui - If you run on a very large high speed track the wing causes too much drag. Cutting the holes out lets air through reducing drag.
fatdoggy is offline
Old 03-28-2004, 10:43 AM
PizzaDude's Avatar
Wouldn't cutting it down in the cxenter (like Alfa 2 or Vectra) be a better way to go...?
PizzaDude is offline
Old 03-28-2004, 10:51 AM
pro3racer's Avatar
yes, cutting the wing in the center would help on the long straights. By cutting the middle, it would look like this(kinda)
lTT----TT, wow's thats bad, but like 1 inch to both sides, from the center, should be cut out. This would eliminate excessive drag on the straights, but still give you downforce in the turns.
pro3racer is offline
Old 03-28-2004, 11:01 AM
PizzaDude's Avatar
So wouldn't cutting out the airvents in Mazda body weaken the spoiler.
Flex?
Old 03-28-2004, 11:06 AM
fatdoggy's Avatar
What is the handling difference with and without the two fins in the wing? Does it make much of a difference?
fatdoggy is offline
Old 03-28-2004, 11:18 AM
pro3racer's Avatar
Pizzadude- the wing already is weak, but if you don't roll over, i won't matter. Actually, i beleive the two sides of the wing to be the weakest, those break off alot at my track(not me, other racers).
Old 03-28-2004, 03:37 PM
JimmyMac's Avatar
Actually the rear wing cannot exceed .4" past the bumper.
JimmyMac is offline
