Old 08-11-2012, 03:49 PM   #91
Trader Rating: 24 (100%+)
i got mine from a guy on this board...good price $130 with i think a gear diff, a spool, extra spur and a tamiya altezza carbon fiber body...not too bad right ?
thefnshow is offline   Reply With Quote
Old 08-11-2012, 10:13 PM   #92
zephuros's Avatar
Whoa! Awesome price! Well now it's time to start caning it around the track. :-)
What motor you running?
awww bollox....
zephuros is offline   Reply With Quote
Old 08-11-2012, 10:27 PM   #93
a viper 21.5...21.5 is what i'm told they out here in illinois at least..this is coming from my local hobby shop guy
Old 08-11-2012, 10:46 PM   #94
zephuros's Avatar
Good stuff. Is there a decent FF scene out there? The minis are popular here in Malaysia but this class isn't really. Having said that there a few races coming up third month and next. I'll be taking part in all!
awww bollox....
Old 08-12-2012, 07:26 AM   #95
i'm not sure..but the sabre looked interesting and i'm a impulse shopper
Old 08-14-2012, 03:52 PM   #96
quick q...where are you guys getting spare parts from...need a few things...thanks
Old 08-14-2012, 03:57 PM   #97
Trader Rating: 62 (100%+)
Email [email protected]. It is a Northern California office
sipaboy is offline   Reply With Quote
Old 08-17-2012, 03:48 PM   #98
hey guys, i need some help...i ordered the 3racing high speed gear set which should be in tomorrow and i need a starting pinion gear choice...i'm running a 21.5 and i know you guys run 17.5...what would be a good starting point ?....i have hpi metric pinions from 28-35 coming in...thanks for any suggestions
Old 08-18-2012, 03:05 AM   #99
zephuros's Avatar
I think a good place to start will be the shortest ratio and then progressively go up in pinion sizes to see what's the fastest lap around your local track. I've done this and quickly found that the final drive that suits me best is 3.92, which I get off using a 28T pinion and 35T spur from the fast gear set. Remember to temp your motor after a few minutes when using larger pinions just so you don't toast it.
This is the process I use when testing at a different track. Remember that the tallest final drive which will give you the fastest straight line speed does not necessarily give you the quickest lap. Keep testing and timing and soon you'll know what works best
Good luck
awww bollox....
Old 08-20-2012, 03:47 PM   #100
ok, i just got my battery hold down an battery brace/weight tray and i'm not seeing how thi is supposed to go on...getting pissed...could somebody possible snap a few pics ? thanks
Old 08-20-2012, 11:22 PM   #101
zephuros's Avatar
It should be straightforward really. Scree the tray into the 2 brackets it comes with and then tape the battery down. I don't have pictures of it coz I use the aluminum battery mounts. It's a lot easier than mucking about with battery tape. If all else fails try the top racing Japan website. The instruction manual shows the details on mounting the battery tray. Note however that the battery will have to go in with the terminals towards fhe rear of the car. Good luck
awww bollox....
Old 08-21-2012, 12:57 AM   #102
i'm using the aluminum hold downs also and i'm just not seeing how they work in conjunction with the weight tray
Old 08-21-2012, 02:41 AM   #103
zephuros's Avatar
Ah ok. I doubt the work together. I've just got my weights fixed on my batteries. Ps, during races it would be wise to get rid of the mounts and to just run with tape. You'll save near 20g in weight
awww bollox....
Old 08-21-2012, 12:07 PM   #104
zep, you're right about the weight tray...how are you guys getting pinions bigger than a 31 on this car ? i have the high speed gear set, using the 33 tooth spur and the motor is all the way back against the motor mount..this car is starting to drive me nuts
Old 10-20-2012, 04:21 AM   #105
Hi
I'm looking for a blank edible pdf setup sheet for TOP Sabre FD.
2Quick is offline   Reply With Quote
Tamiya mini cooper sipaboy Electric On-Road 29687 12-10-2017 04:07 AM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 732 10-12-2017 03:34 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5806 09-22-2017 04:06 PM
X-EVO MTX3-B Malaysian R/C Racers 20 02-02-2010 08:51 PM
