Old 09-19-2011, 09:06 AM   #46
Haha i just read my own comment on this and was about to use it in a new one.
I have without even remembering that this car would come as a RWD tourer buildt my own Rwd Touring car out of a T1 FK05. was so much fun. Without the spool it was nice to pick the line i wanted.
I like the layout on this sabre if its so front heavy as a RWD car too.
Because i found that my own car got to rear heavy with same tires front and back. If i could work the front tires more so it becomes more understeery i think it would be better.
I tuned down my 500Watt motor to 45% on a small indoor track. It was managable.
Low grip track. carpet.
1203grams 7XXgrams at the rear. so quite a bit rear heavy.
MatsNorway is offline   Reply With Quote
Old 12-18-2011, 06:51 PM   #47
Groomie's Avatar
Default Setup
Hi All
Does anyone have a setup for the sabre
Ran mine yesterday and was really taily off power. I also found using the u-pro diff with standard oil in it made it way worse and ideas and help would be great
Regards Groomie
WSRC open and ready to race
Check us out at
http://www.facebook.com/WesternSydneyRaceCentre
Groomie is offline   Reply With Quote
Old 12-18-2011, 07:21 PM   #48
caltek1's Avatar
Trader Rating: 36 (100%+)
Groomie,
Try softening the rear springs and possibly standing up the rear shocks. The other option is to run softer rear tyres whilst testing.
You should send a PM to Jeff or Rod asking what they are using. For TITC you will require the speed gear set.
Jase,
I have fixed my FF and it works very well at Penrith and Whalan. It just did not like the TITC tyres front and rear. I think getting to the track early,(RC Addict) and testing with goop might fix the issue.
It would pay to have swaybar sets and softer springs for car tuning.
Later,
Calvin.
caltek1 is offline   Reply With Quote
Old 12-18-2011, 07:34 PM   #49
caltek1's Avatar
Groomie,
I can not say I have had great success with the u-pro oil gear diff. I would be stocking some spares if I was you. Not being negative, but used it in TC and then modified one for a mini, did not last long before stripping the internals.
RC Addict is very high grip, so there will be alot of strain on the oil gear diff.
I also forgot to add you can change rear roll centres, trackwdith etc to get more rear grip. You also have to change the way you drive when running a FWD car, certainly not the same as a TC.
Calvin.
Old 12-18-2011, 07:45 PM   #50
I have the ball diff in the car at the moment and it was getting good drive out of the corner. Will try some gear diffs later on.
ARC R10 2013
Wylie27 is offline   Reply With Quote
Old 12-19-2011, 01:10 AM   #51
Ive heard that a 3Racing M05/M06 gear diff fits straight in with 42-43mm axles
Something with the rear end geometry is just wrong, soft springs, soft oil, and lay them over should give some more rear bite. The car is just so much stiffer in the ass than it should be.
Cal - Using different tires is cheating
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 12-19-2011, 01:33 AM   #52
caltek1's Avatar
Bradd,
Here at home we are all using softer rear tyres.
As you have said though, running a softer rear end will get you the extra grip. Just takes practice and testing different things. The only problem is when you get to TITC you will have to start again, as the tracks are so different from here and running same tyres front and rear.
Later,
Calvin.
Old 12-19-2011, 01:49 AM   #53
Originally Posted by caltek1 View Post
Bradd,
Later,
Calvin.
Thats where i run into problems every year at TITC, the grippy conditions turn everything upside down.
Old 12-19-2011, 02:24 AM   #54
caltek1's Avatar
Well you will not be lonely. That is why I am arriving early, so I can test as many different settings as I can. Then when the grip level becomes insane I will be back to square one again.
Thanks for the info on the 3Racing MO5/MO6 oil gear diff. I wonder if I should get around to building one of the Sabres in the cupboard or see if I should sell teh kit as spares.
Calvin.
Old 12-19-2011, 04:20 AM   #55
Cal,
How nany sabres do you have?
ARC R10 2013
Old 12-19-2011, 04:25 AM   #56
Thinking of getting some 3degree block for the rear. Anybody else tried this?
ARC R10 2013
Old 01-22-2012, 03:30 AM   #57
Rod M's Avatar
new front spool just released, I have a few on the way for testing, and if they are good then will get a few more for stock,
TOPRACING.NET.AU Australian Importer of:
T.O.P. Tokyo Hobbies Optional Parts,
Team Trinity , BL Motors and Tyre compound
Team Tekin , ESC's, motors,
Elangears, Chargers,
Rod M is offline   Reply With Quote
Old 01-22-2012, 03:42 AM   #58
mingnon's Avatar
Looks good, cant wait to grab one after testing is done
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 01-22-2012, 04:11 AM   #59
Spool or gear diff??
ARC R10 2013
Old 01-22-2012, 04:25 AM   #60
Rod M's Avatar
I have run a spool in the Sabre for a while but I would not recommend it as it pushed too much around corners,
this is what I was using,
Tamiya mini cooper sipaboy Electric On-Road 29687 Yesterday 04:07 AM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 732 10-12-2017 03:34 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5806 09-22-2017 04:06 PM
X-EVO MTX3-B Malaysian R/C Racers 20 02-02-2010 08:51 PM
