Rubber or Foam
Old 02-01-2010, 06:48 PM
Default Rubber or Foam
I just was wondering i been out of rc racing for about 4 years now and i was wondering if the main classes people run for on road carpet .....is it foam still or now rubber i just wondering thanks
travis_g is offline
Old 02-01-2010, 06:49 PM
trerc's Avatar
Trader Rating: 89 (100%+)
Rubber's hot right now
trerc is offline
Old 02-01-2010, 07:06 PM
pakk's Avatar
Trader Rating: 80 (100%+)
At my local track, the only class the runs rubber is TC. All other classes run foam.
pakk is offline
Old 02-01-2010, 08:20 PM
TRXRACER99's Avatar
Trader Rating: 10 (92%+)
the only classes that run rubber are tc and 1/8 gt.
the 1/12, F1, WGT, most 1/8
what class are you thinking of running in.
TRXRACER99 is offline
Old 02-01-2010, 11:23 PM
Toh WL's Avatar
well from my end... 1/10 GP cars uses foam. for 1/10 EP they uses rubber. there are foam tires in use by 1/10 pan cars.
Toh WL is offline
Old 02-02-2010, 01:58 AM
tc3team's Avatar
If you are returning to rc after 4 years I would suggest rubber, as with foam you have to worry about changing your gearing as the tyres wear, truing them down to size and adjusting droop as they wear. Foams can chunk too.
when you're settled though, grab yourself some foams
tc3team is offline
Old 02-03-2010, 09:56 PM
Trader Rating: 20 (100%+)
Ok so I got a question noticed people at our local track using tire warmers on rubber tires is this a must?
1sicls1 is offline
Old 02-04-2010, 01:06 AM
tc3team's Avatar
At club level I would say no.
By the time you've taken them off, walked with your car to the track and waited for the race to start I doubt you have much advantage from them really.
Ive club raced for years and never felt at a disadvantage from not having any, but this is only imho... I think you could spend your hard earned on something better before buying them
tc3team is offline
Old 02-04-2010, 02:12 AM
Tire warmer is not a must item, although it will help the tires to warm up faster. I have tried with and without.
Without warming the tires, I would struggle for grip for 2-3 laps, then the tires would be fine.
With warming, the tires will provide instant grip.
Because I bought one, I would use it.
hardmankam is offline
Old 02-04-2010, 08:53 AM
PDX-Spike's Avatar
I can't remember the exact numbers from the IIC last year. In the 17.5 TC class (or was it 13.5?) there were 70 entries in rubber were and 20 in foam.
Check your local track and see what they're running. Foam and rubber chassis' are different. A foam-specific chassis is stiffer (thicker graphite) than a rubber tire chassis.
From what I've read in these forums, the foam tire TC is mostly a US thing. In Europe (and Japan?) it is almost entirely rubber.
PDX-Spike is offline
