I got a dud monster stock, what can I do?
#16
ok, it was geared around the 6.73 mark. I'll use a smaller pinion when I go back.
I'll get it trued tommorrow, and i'll install the 4499 dual shunt brushes, but how do you align them? i wasn't following-do you need a rectanglular brush to set it?
Also, should I stick with the stock brush setup or go a bit softer? i'm kinda hesistant to go softer because I race on a tight track.
thanks...
thanks...
#17
I've never quite understood the reason behind aligning the brushes. It seems to me that if the brushes are slightly cocked, it will adversely affect performance at first, but once the brushes wear down and seat themselves, it won't make much difference if they are off a couple mils in either direction. Additionally, if the brush were at a slight angle, it would give more contact area. While it might cause a little bit more friction, it would also yeild more area for current to flow through.
I'm probably dead wrong on this, but if anyone can explain why, I'd be interested to hear their explaination.
#18
Do everything this website tells you to and you should have an ok runing motor.
http://www.motortuningsecrets.com/tunestockmotor.html
There is always a chance you just bought a real dog of a motor.
#19
Griffin - I'm not sure if this is right but. If the brush isn't perpendicular it causes drag, becuase as well as the brushing pressing foward onto the comm you also have some side pressure and more heat. Having brushes that arn't aligned can also cause hung brushes as well as extending comm wear during break-in.
