Old 03-26-2004, 11:14 AM   #1
acutts's Avatar
Default Car troubles?
Hi
Not sure if anyone has any ideas.... My mates car (Pro4) pulls heavily to the right under full power and I am not sure what the problem is. Under slight power ity drives perfectly straight but under full throttle it steers right??
Any help appreciated.
acutts is offline   Reply With Quote
Old 03-26-2004, 05:02 PM   #2
DT-Skyline's Avatar
Send a message via AIM to DT-Skyline Send a message via Yahoo to DT-Skyline Send a message via Skype™ to DT-Skyline
Your ST(steering) Trim might be off. Adjust it on your controller. Or, adjust adjust the servo on the car. If all esle fails, bring it to a Hobby shop.
DT-Skyline is offline   Reply With Quote
Old 03-26-2004, 05:19 PM   #3
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Check the tweak of the car. If there is more weight on one corner than another or vice versa side to side, it will make the car pull funny under heavy acceleration loads. Check your droop and ride height as well. Also check your toe in and camber. This can all lead to funny handling if something is out of place.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 03-26-2004, 05:20 PM   #4
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
you have something binding in the suspension or dirve train a messed up setup. Have you checked the suspension on a tweek board? You could also be feeling the torque steer that's inherint in a shaft drive design
Jon Kerr is offline   Reply With Quote
Old 03-26-2004, 05:21 PM   #5
Tek Nickal's Avatar
Sounds like there is too much weight on one side of the car, wayy too much, and the trim is also wayyy off.
Tek Nickal is offline   Reply With Quote
Old 03-27-2004, 12:28 AM   #6
acutts's Avatar
Thanks for all the info guys ..... Car is being broiught round today and I am going to have a look and put it on my setup board.
Cheers
Old 03-27-2004, 06:16 AM   #7
TeamPink91's Avatar
Send a message via AIM to TeamPink91
I thought it could be the diff slipping and unloading to one side.
TeamPink91 is offline   Reply With Quote
Starter Box Troubles. Mazda787b Rookie Zone 2 09-26-2006 10:50 PM
TS4N troubles TS4N Noob Australian Racing 1 06-23-2006 10:01 PM
tt-01 troubles nekmiyevo2 Electric On-Road 21 08-11-2005 07:34 AM
OS TR(P) Troubles Glenn Nitro On-Road 12 08-28-2002 02:38 PM
