Old 02-01-2010, 03:19 PM   #16
Trader Rating: 20 (100%+)
soldering on a new cap today. I think I caught it in time, but we will see. Thanks again.
storytyme is offline   Reply With Quote
Old 02-01-2010, 05:00 PM   #17
I'll put my hand up for doing this too!
I only had it together for about 1 second. I didn't even try it again until I replaced the cap. Wired it up correctly, and it goes fine. In saying that, it was very brief and I got no smoke!
Like said, you have probably fried some fet's, so even if it works, it may struggle under load and you will wreck more of it!
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 02-01-2010, 05:24 PM   #18
Did you see where the smoke came from? Did it come from the cap or from the ESC itself? If just from the cap you'll be fine just replacing the cap. If from the ESC itself it may have other damage. My guess is that if it is working you probably just blew the cap.
Old 02-01-2010, 06:03 PM   #19
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
The unit would not work if he had a bad fet.
The smoke most likely came from the cap.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-01-2010, 06:18 PM   #20
wingracer's Avatar
Trader Rating: 24 (100%+)
I'm curious, could hooking it up backward damage it even with the switch off?
I know it would still blow the cap but could it kill the esc too?
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 02-01-2010, 06:42 PM   #21
Team Tekin
Randy_Pike's Avatar
Yup! DO NOT do that!
Old 02-01-2010, 09:30 PM   #22
TRXRACER99's Avatar
Trader Rating: 10 (92%+)
i did the same thing the other day and the cap smelled like ass but i sent it into tekin and hopefully it was just a fet and i can get racing again!
TRXRACER99 is offline   Reply With Quote
Old 02-02-2010, 12:00 AM   #23
It came from the cap and was the oozing liquid. I touch the wrong connectors for less than a second. soldered on a new cap and now just need to clean up the wires to the motor to test it out. I will post back once I get a test run on Wednesday. Thanks for all the replies.
Old 02-02-2010, 08:14 AM   #24
T Tom's Avatar
Trader Rating: 17 (100%+)
How can you tell if the cap is blown ?
T Tom is offline   Reply With Quote
Old 02-02-2010, 08:40 AM   #25
Team Tekin
TY@TEAMTEKIN's Avatar
Warranty is 120 days guys, but it doesn't cover reverse polarity. We'll still work with you on it though!
If it still works, you are very lucky my friend, I reversed the plugs on my RS in my Slash because the battery I was using was backwards from the other 3 I had and it touched less than a second, snapped and it's been dead since. I've since quit using bullet connectors
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 02-04-2010, 11:41 AM   #26
TESTED THE ESC YESTERDAY AND EVERYTHING WORKED GREAT. I WILL CHALK THIS ONE UP TO LUCK. THANKS FOR EVERYONES INPUT.
Old 02-04-2010, 02:42 PM   #27
tc3team's Avatar
Not always, but I think they usually puff out a bit bigger than their usual size...
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tekin Rs/Rs pro V200 offroad setups only JdogL Electric Off-Road 272 02-04-2010 11:54 AM
What 13.5t to go with new Tekin RS Pro ? amnesia Electric On-Road 10 09-06-2009 02:20 PM
Tekin Brushless system? any good? meon99 Electric On-Road 69 03-13-2009 11:36 PM
