r3 vs 415
Old 03-26-2004, 01:05 PM
  #16
JusBox's Avatar
Originally posted by Aku-Man
For pro4, you need to take out 16~17 screws to work on diffs. To change spur gear, need to take out 12~13 screws.
oh ok then it's a pain in the butt too.
JusBox is offline
Old 03-26-2004, 01:07 PM
  #17
Registered User
My mistake, to change spur gear on pro4, need to take out 14~15 screws.
Aku-Man is offline
Old 03-26-2004, 01:17 PM
  #18
i dont find it hard to work on the diffs of the R2 ...takes like a minute or two to get it out
R/C Anonymous is offline
Old 03-27-2004, 07:34 AM
  #19
try working on the tamiya evo2.
dual bulkheads with diffs mounted in plastic cases too.
it takes about 35mins to get 1 diff out.
trf racer is offline
Old 03-27-2004, 08:51 AM
  #20
That's totally wrong.
With 12 screws you can have COMPLETE access to the WHOLE drive train, including the front and rear gearboxes, spur gear etc...
13 screws if you use the central stiffener.
It's still more than on the SD or Evo 3, but I find it very nice to be able to do that, you have a clear view of the drive train.
Back to the subject, both are very fast, and both hard to maintain. Yet I found a belt driven car should be easier to drive than a shaft driven car, because the drive train feels smoother on power.
Cobra81li200 is offline
Old 03-27-2004, 08:54 AM
  #21
Registered User
Do you have Pro4? Because you're wrong. You forgot to count screws on steering and motor mount. You need to remove entire upper deck you know?
Well, I like the clean look on Pro4. I might get it again, if my pocket allow me.
Aku-Man is offline
Old 03-27-2004, 09:05 AM
  #22
I don't own a pro4 and I did count these screws. I know what I'm saying, I did it myself on a friend's car.
What you forget, is that you don't need to get the upper part of the gear boxes unscrewed, you can keep them attached to the upper deck, so that's 4 screws less than what you think.
What I forgot is that you need to have the shocks unscrewed, so that's 4 nuts (like me, he he) I forgot, not screws.
