Where can I get foam to make foam tires? >
Old 01-31-2010, 07:59 PM
  #16
pakk's Avatar
Trader Rating: 80 (100%+)
I think he was talking about me. I was looking for 12th scale donuts.
pakk is offline
Old 01-31-2010, 08:10 PM
  #17
BUDRACER1's Avatar
Trader Rating: 38 (100%+)
Oh my bad...there I go again not reading all the details. lol
Contact John Foister at Johns BSR Racing Tires, He should be able to hook you up.
thanks JB
BUDRACER1 is offline
Old 01-31-2010, 10:02 PM
  #18
trerc's Avatar
Trader Rating: 89 (100%+)
Yes i was, like BUDRACER1 said contact John at BSR he will likely be able to help you out.
trerc is offline
Old 02-03-2010, 10:15 PM
  #19
fallguy's Avatar
http://www.mcmaster.com/#foam/=5nzyu7
im going to try and figure this out.. i have a bunch of chunked tures that i would like to redo for my pan car
or im going to get the foam sheet from a place like this (this one is near my work)
http://www.polarbearrubber.com/sheet.htm
fallguy is offline
Old 02-03-2010, 10:28 PM
  #20
Geezatec's Avatar
Post a couple photos of chunked tires you have. What kind of surface you run on? Temp of asphalt? What glue are you useing?
Geezatec is offline
Old 02-03-2010, 10:36 PM
  #21
fallguy's Avatar
carpet and we are chunking them from bad driving ( 1st season of pan car for a few of us) the tires are pre mounted jaco,crc and some other brands.
fallguy is offline
Old 02-03-2010, 11:17 PM
  #22
Geezatec's Avatar
Rather you can post a photo, so I could see where they're chunking. Middle or on the edges. They chunk not of bad driving. I seldomly see them chunk on carpet. How far do you run them by diameter?
Geezatec is offline
Old 11-09-2011, 05:55 AM
  #23
mailboxck's Avatar
Originally Posted by rccartips View Post
I use slippers. You need to feel the compound with your fingers and choose the right one.
I prefer the grip of the slippers foams over Tamiya tires. Around 3 hours of run time.
Was it simply coincidence that the saw's inner diameter and outer diameter were the same size as tamiya tires? I'm thinking about doing this on my own
mailboxck is offline
Old 11-09-2011, 06:00 AM
  #24
sosidge's Avatar
Madness... I love it!
sosidge is offline
Old 11-09-2011, 06:08 AM
  #25
Mailbox, you can adjust the hole saw for various diameters.
Sometimes I make the tires simply because it works better that what I can buy
rccartips is offline
Old 11-09-2011, 05:56 PM
  #26
WC
WC's Avatar
Trader Rating: 28 (100%+)
heh, never knew ppl would buy flipflops for rethreads
closed cell EVA foam is not hard to buy in sheets, can specify shore you want
they are adjustable... for inner hole, go 1 smaller rather than larger
if you're smelling burning, sounds like you're cutting unlubricated!
we used a giant drillpress indoors, zero ventilation. Goes slow like 200rpm.
best lube? plain water in a trigger spray bottle, that's all u need
WC is offline
Old 11-09-2011, 07:13 PM
  #27
mailboxck's Avatar
Thanks for the tips! I'll do this once I wear out my current set of foams
Old 11-12-2011, 07:00 AM
  #28
TRADLER's Avatar
Default RIMS
I ve got the foams I want but I can t find rims other then CRC for 12th scale does anybody have another supplier.
TRADLER is offline
Old 11-12-2011, 01:50 PM
  #29
Windtunnel sells rims, and I think rc4less does too.
When re-using rimms, the CRC's will melt, but Jaco wheels do not. (atleast for 1/12 scale).
Shawn
Shawn68z is offline
Old 11-12-2011, 04:24 PM
  #30
TRADLER's Avatar
Shawn
I couldn't find 12 scale rims on either of those sites. do you have a product number?
TRADLER is offline
