Old 03-25-2004, 09:20 PM   #16
stankulas's Avatar
CAIN aaaaaaaa i think iam in trouble
stankulas is offline   Reply With Quote
Old 03-26-2004, 02:17 AM   #17
Default I would also say...
get the IRS aluminum input shafts and an AE aluminum shaft.
Nightbreed is offline   Reply With Quote
Old 03-26-2004, 05:52 PM   #18
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Here is the chassis with the modifications done.
Speedo is offline   Reply With Quote
Old 03-26-2004, 05:53 PM   #19
Moderator
Speedo's Avatar
Another
Old 03-26-2004, 05:54 PM   #20
Moderator
Speedo's Avatar
Here is the under-side. I did a quick sanding with 220 grit, and finished it off by wet-sanding with 1000 grit for about 10 minutes.
Old 03-26-2004, 05:55 PM   #21
Moderator
Speedo's Avatar
Here is the side, where I did most of the sanding with 220 grit and polished it with 1000 grit by wet-sanding. Everything is incredibly smooth now.
Old 03-26-2004, 06:05 PM   #22
Send a message via AIM to True R/C Racing
Default Re: I would also say...
Nah, for better Performance Get New Diggity Design Shaft. Its like $30 and I heard they work great. Cant hurt give it a try
True R/C Racing is offline   Reply With Quote
Connectors and battery bars make a difference? aus jd 2703 Electric On-Road 9 12-31-2006 07:14 AM
how much difference do chargers make Ercle Rookie Zone 9 11-26-2003 08:14 PM
Will 235mm 4wd make a difference in selection? BG Australian Racing 22 01-21-2003 02:05 PM
