Novak Brushless in Xray T1R >
Old 03-24-2004, 07:58 PM
Default Novak Brushless in Xray T1R
I am installing a Novak Brushless system in my T1R and it appears I will need to grind away some of the chassis in order to gain enough movement of the engine to properly adjust the gears. I am using the standard 93t spur with a 27t pinion. Has anyone else installed this motor? Any installation issues? Solutions?
Lano is offline
Old 03-24-2004, 10:13 PM
lee82gx's Avatar
Hold it!
Go with a smaller spur(90T) and there will be no need to do so.
I've run the same combo as yours with the above gearing and it's fine.
7.75 is very low and you will get tyre slip on hard throttling.
Try something near the 6.8 region.
Good luck
lee82gx is offline
Old 03-24-2004, 11:28 PM
Thank you.
I really didn't want to get out the Dremel. I'll try the different spur and overall gearing you recommend
Lano is offline
