Old 03-23-2004, 09:52 PM   #1
Send a message via AIM to LancerEVO
Default Spur Gear
how many teeth does the stock TC3 spur gear have?
LancerEVO is offline   Reply With Quote
Old 03-23-2004, 09:54 PM   #2
Talking Re: Spur Gear
72.. teeth..
Mark Barden .
mb racer is offline   Reply With Quote
Old 03-23-2004, 09:59 PM   #3
so what would my ratio be i have
24 tooth Pinion
72 Tooth Spur
Old 03-23-2004, 10:01 PM   #4
JusBox's Avatar
24 tooth Pinion
72 Tooth Spur
7.50
JusBox is offline   Reply With Quote
Old 03-23-2004, 10:03 PM   #5
thanks alot but i got another question
i got a 19 T motor what pinion and spur gear should i get?
Old 03-23-2004, 10:32 PM   #6
DT-Skyline's Avatar
Send a message via AIM to DT-Skyline Send a message via Yahoo to DT-Skyline Send a message via Skype™ to DT-Skyline
Try 96-100 tooth spur gear and 36-40 pinion. I use this in both stock and 19t. It's a good combo
DT-Skyline is offline   Reply With Quote
Old 03-24-2004, 12:02 AM   #7
Brandon R's Avatar
24 tooth Pinion
72 Tooth Spur
no it isnt 7.50....
you divide the spur number of teeth by the pinion number of teeth to get the ratio...in your case it would be 72/24=3.00
Brandon R is offline   Reply With Quote
Old 03-24-2004, 12:23 AM   #8
so how fast should my car be????
Old 03-24-2004, 12:36 AM   #9
Brandon R's Avatar
the lower the number in gear ratio the more top end or mph you will have...the higher the number the faster it will take off but lowers the mph
Old 03-24-2004, 11:56 AM   #10
Rob Hochberg's Avatar
Send a message via AIM to Rob Hochberg
Originally posted by Brandon R
no it isnt 7.50....
Yes it is 7.50.. you need to mutiply 3.0 by 2.5 ( the TC3's internal drive ratio.)
The formula for FDR: Spur/Pinion x your car's internal drive ratio= Final drive ratio
Rob Hochberg is offline   Reply With Quote
Old 03-24-2004, 11:58 AM   #11
JusBox's Avatar
no it isnt 7.50....
owned. you have to factor in the internal ratio, which i did.
Old 03-24-2004, 12:00 PM   #12
LOL AWOL.. good thing we agree. BrandonR- 0\/\/|\|3|)
Old 03-24-2004, 12:32 PM   #13
Brandon R's Avatar
he asked what would his ratio be with 24 and 72 right? not final ratio with internals. so no not owned. Do you factor in the transmission ratio on a real car? NO so why factor them in on these? It makes it much easier to not factor that in.
Old 03-24-2004, 01:50 PM   #14
JusBox's Avatar
I think he meant to ask for final ratio as he isn't running a pan car w/direct drive so just the spur/pinion ratio wouldn't be too useful for him.
o wne d
Old 03-24-2004, 03:50 PM   #15
Brandon R's Avatar
whats the difference between knowing the final ratio and the direct ratio? If he changes the pinion to a 30 and drops down to a 2.40 ratio does that mean it would do the same thing as calulating the final ratio? yes it will make everything the same thus no need to worry about final ratio unless you change the internal gears. Its much easier to tune the direct gear than worry about all the other stuff right? If you go through all that trouble i feel very sorry for you!!
Gear Ratios/ Spur Gear Sparky7B Rookie Zone 2 02-26-2008 10:03 PM
Jammin Diff, w/ Lightened Spur And Extra Spur Gear prphze R/C Items: For Sale/Trade 0 10-07-2007 03:40 PM
spur gear atomicandy Electric On-Road 6 03-03-2006 07:28 AM
spur gear monstermatt Monster Trucks 8 07-19-2004 01:07 AM
Associated TC3 Spur Gear Brazilian Electric On-Road 2 01-14-2002 11:05 PM
