Old 03-24-2004, 05:45 PM   #16
JusBox's Avatar
Originally posted by Brandon R
whats the difference between knowing the final ratio and the direct ratio? If he changes the pinion to a 30 and drops down to a 2.40 ratio does that mean it would do the same thing as calulating the final ratio? yes it will make everything the same thus no need to worry about final ratio unless you change the internal gears. Its much easier to tune the direct gear than worry about all the other stuff right? If you go through all that trouble i feel very sorry for you!!
You have to have a baseline. The final ratio is your base line and you can go up or down from there. If you print out a chart for your specific car you can see at a glance what your ratios are for a given spur/pinion combo.
JusBox is offline   Reply With Quote
Old 03-25-2004, 04:27 AM   #17
MrEs's Avatar
Send a message via ICQ to MrEs
brandon u are wrong, final ratio lets u compare gear ratios between cars because it takes into consideration thier differant differential ratios.
MrEs is offline   Reply With Quote
Old 03-25-2004, 04:36 AM   #18
Andrew_XXXs's Avatar
Even final drive ratio isn't that helpful at the track unless there are many people running the same car with the same diameter wheels, who know their transmission ratio. Use rollout as your benchmark (which is how far the wheel travels for each revolution of the motor).
Check www.arroyoc.com There is a link in the tools section that has a final drive/rollout/mph tool that is very useful.
Andrew_XXXs is offline   Reply With Quote
Old 03-25-2004, 02:11 PM   #19
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Old 03-25-2004, 02:12 PM   #20
Old 03-25-2004, 02:13 PM   #21
JDXray's Avatar
Send a message via AIM to JDXray
LOL HAHAHHA
JDXray is offline   Reply With Quote
Old 03-25-2004, 02:22 PM   #22
JusBox's Avatar
Old 03-25-2004, 02:49 PM   #23
Brandon R's Avatar
exactly...thats why there is no point in that calculation! The easy and very simple way to tune with gear ratio is the direct pinion to spur all you other guys have fun jackin around with your charts and calulators
Brandon R is offline   Reply With Quote
Old 03-25-2004, 03:11 PM   #24
JusBox's Avatar
You're missing the point. Do you really think you're turning us on to something new here? Of course you tune the ratio with your pinion and spur but unless you know the final ratio you hope to achieve you're not doing much good. Why are you fighting this fact?
The chart can show you what your ratio will be with certain spur/pinion combos. You don't need a calculator. For example, some motors need to be run at certain final ratios for optimum performance... unless you know how to get this you'll be either under geared or fry the motor.
Old 03-25-2004, 03:17 PM   #25
Using final drive ratios is a simple way to tell someone your gearing for a specific motor. If someone asked me what I geared a D6 8x2 I wouldn't say 24/96, I'd say 8.7 so that it's relevant to every car out there.
Old 03-25-2004, 07:58 PM   #26
MrEs's Avatar
rubbers are the same, so if u run rubber then your diamater doesnt change and FDR is very handy on sharing setup..
Old 03-25-2004, 08:42 PM   #27
Send a message via AIM to LancerEVO
LancerEVO is offline   Reply With Quote
Old 03-25-2004, 08:53 PM   #28
If you want to be able to compare your cars gearing to anothers (a different car) then you need to talk final drive ratio (rollout is better). If you try to copy someone elses gearing you will have lots of fun on a tc3 which uses small spurs/pinions compared to something like a 414. Try to fit a 90t (48p) spur in your tc3!!!
If you want to be able to understand what someone is saying, learn to talk their language... its that simple.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Gear Ratios/ Spur Gear Sparky7B Rookie Zone 2 02-26-2008 10:03 PM
Jammin Diff, w/ Lightened Spur And Extra Spur Gear prphze R/C Items: For Sale/Trade 0 10-07-2007 03:40 PM
spur gear atomicandy Electric On-Road 6 03-03-2006 07:28 AM
spur gear monstermatt Monster Trucks 8 07-19-2004 01:07 AM
Associated TC3 Spur Gear Brazilian Electric On-Road 2 01-14-2002 11:05 PM
