Old 03-11-2002, 03:48 PM   #1
Moderator
pc9840's Avatar
Send a message via ICQ to pc9840 Send a message via AIM to pc9840 Send a message via Yahoo to pc9840
Default Reedy Quasar Pro
Got mine about a week ago. Works good so far. Stays cool, no false peaks, user freindly, loud audible tone, accurate readings. I like it. Anyone else got one? Find anything wrong yet? I am charging 3000HV @ 7mv @ 6.0 amps. Works good.
[email protected] <><
"The minimum wouldn't be the minimum if the minimum wasn't good enough"
pc9840 is offline   Reply With Quote
Old 03-11-2002, 04:56 PM   #2
Moderator
Cmotif's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Cmotif
Default Good to see you on here!
So you are collecting up a bunch of new gear. Very cool.
Question, Since it will do Nimh, will it also do AAA Nimh? Just got a couple of Mini Zs, and I think that I am scared already of the Nimh and the slow charger that will be coming with them.
Cmotif <><
International Racing Team Member #18
IRT Established: 1999
Everything About You -- Sanctus Real
www.dontblamejesus.com
Cmotif is offline   Reply With Quote
Old 03-11-2002, 06:14 PM   #3
Send a message via Yahoo to Rob P
Default Quasar Pro
Just got one this weekend. Seems to do a great job. I really like it. As for the AAA no problem.. You can just lower the amp rate to <1. It is all adjustable.
Rob
Rob P is offline   Reply With Quote
Old 03-12-2002, 11:41 AM   #4
rc-zombies's Avatar
I got mine last week... had to send it back to AE for replacement.
Software was acting up. It would shut itself off when I want to change view screens and sometime it would lock-up and can't change any setting without unplugging the unit. and then I get this average volts reaching at higher than 60volts! and the lower half of the LCD panel would dissapear. and dingbat text would sometimes show up, and . . . .
AE costomer service was great. Just send it back and I'll get a new one. Hopefully I'll have better luck with the new one.
When it did work.. it worked great. and yes it will charge AAA nimh cells. The audible tone is way too loud. When I get it back, I'm just going to open up the case and put a piece of tape over it to tone it down. (of cource after the Warrenty expires)
I believe the Quasar Pro is made from Integy. Functions are identicle to the 16X5 that I also own. If this is the case... the optional backlit module available from the Integy website can be installed. I'm going to order one and try it. The only advantage over the 16X5 is that you can turn trickle off 0.0mv. and very compact no external power supply needed.
The Quasar Pro is probably the best charger on the market today.
It does everything.
Old 03-12-2002, 11:52 AM   #5
Regional Moderator
Darkseid's Avatar
PC9840: good to see you on the boards!
TLR 22...Tamiya F104...
Old 03-12-2002, 12:11 PM   #6
Trips's Avatar
Trader Rating: 16 (100%+)
Looks like I'll be getting the Quasar Pro... The only thing I don't like about my 16x5 is the after charge trickle.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 03-12-2002, 12:18 PM   #7
I haven't seen any problems at all. Really like it. Let me know about the backlit addition. It should depend on what kind of LCD is in there. You bascially need to supply 5v to 2 pins put a pot on 1 and get a contrast control. As for Speaker. Yea really loud. I was thinking about opening up and seeing if there was a pot for that too.
Rob
Old 03-12-2002, 06:34 PM   #8
Moderator
Speedo's Avatar
Sounds like it is a good charger. What amp rate can it charge up to? The only thing that sounds bad about it is it can only discharge up to 20 amps, but that is a small price to pay considering the difference in price between it and the T35.
Something is wrong with my T35 It has about 3 differnt tones, and randomly changes between them...heh.
Speedo
Speedo is offline   Reply With Quote
Old 03-12-2002, 07:34 PM   #9
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
It will charge up to 6.5 amps.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 03-13-2002, 11:59 AM   #10
Ian S's Avatar
The new version pro trak has programable tones that uses the same code as nokia mobile phones so you can have the same tone on your charger as you do on your mobile
Ian S is offline   Reply With Quote
Old 03-13-2002, 02:42 PM   #11
I don't own a Quasar Pro... but personally, I think the fact that it can only charge up to 6.5 A is a problem. Right now, people are advocating the use of 7 A or so for Sanyo HVs. That's stretching the Quasar, surely. And what about other cells that will will be released in the future? Just my 2 cents...
jwwu is offline   Reply With Quote
Old 03-18-2002, 12:17 PM   #12
rc-zombies's Avatar
I just received the replacement Quasar Pro I sent back for repairs last week. and guess what... It's still broke... Now it won't even power up. I guess I'm going to send it back again for a refund.
I just ordered the Integy 16X9 from Stormer for only $30.00 more.
that has the same features, but w/backlit display, has an internal 14amp power supply that can also power another accessories like another dc charger, dyno, tire warmers etc.
Old 03-18-2002, 12:44 PM   #13
D_Ames's Avatar
Send a message via AIM to D_Ames
Let us know how the 16x9 works out because both chargers are made by the same comapny.
D_Ames is offline   Reply With Quote
Old 03-18-2002, 01:07 PM   #14
rc-zombies's Avatar
rcracingfreak
I used to own the 16x5 which is pretty much identical in functions as the 16x9 but power supply is built in. I never had any problems with the 16x5. I've also had there other chargers also the 16x2.5pro with no problems. I think I'm going to have better luckl with the Integy 16X9. Let you know how it turns out.
Old 03-18-2002, 01:11 PM   #15
fatdoggy's Avatar
rc-zombies - I order'd my 16x9 from stormer last saturday. Great deal if you ask me.
fatdoggy is offline   Reply With Quote
WTB..REEDY QUASAR PRO... frankiecmgt R/C Items: Wanted to Buy 2 03-23-2006 07:43 AM
JR XS3, LRP 7.1, Reedy Quasar Pro, Reedy 12 double S.Heath R/C Items: For Sale/Trade 1 10-31-2005 07:48 AM
reedy quasar pro LT R/C Items: For Sale/Trade 1 03-09-2005 03:04 PM
Lrp V7 and Reedy Quasar Pro R.Fenstermacher R/C Items: For Sale/Trade 12 10-26-2004 06:06 PM
reedy quasar pro ver.2.1 Mo Denton R/C Items: For Sale/Trade 5 08-27-2004 08:32 PM
