Too many stock motor choices >
Old 03-23-2004, 12:20 AM
DOMOisCOOL's Avatar
Angry Too many stock motor choices
Im trying to decide on a modified stock motor for a tight track with a short straightaway.
Ive been looking at Team Paradigm's Monster Stock and Yokomo MVP, Fast Forward's Tomahawk Stock, and Team 1 R/C's Monster stock. I can't decide on which one to get
Which one do you guys prefer? All of these motors I picked obviously has a lot of torque, which I need for my track.
DOMOisCOOL is offline
Old 03-23-2004, 12:50 AM
Cole Trickle's Avatar
I dont think there's anything called a modified stock... it's either stock or modified...
Anyway, the Monster (regardless of the tuner), is more RPM strong, while a motor like the Peak Hellfire is more torquey.
But it'll also depend on driving style. If you have a very floating driving style, an RPM oriented motor might be the way to go. With proper gearing of course...
Cole Trickle is offline
Old 03-23-2004, 05:35 AM
berger's Avatar
What about something like a P2k2, plenty of torque suitable for a small track?
berger is offline
Old 03-23-2004, 07:08 AM
Tech Legend
Cain's Avatar
Trader Rating: 289 (100%+)
According to Big Jim, the P2k2 or the MVP would be a great choice. If you get the MVP, make sure to get it with the trimmed brushes, you probably will have to gear up abit than you would with the regular MVP brush setup.
I should be testing out my MVP tommorrow. Mine isn't a tuned model so I will be doing this on my own but I have the brushes and can set the springs up right. If Paradigm has the MVP tuned in stock, would be a great one to get.
Cain is offline
Old 03-23-2004, 07:56 AM
Trader Rating: 16 (100%+)
Default Re: Too many stock motor choices
Sounds like RC Tech's track. You should go to the race there (next Tuesday) and see for yourself what proves to be fast. Then talk to the guys racing there to get their tales.
I would give the nod to an out-of-the-box Monster Pro labeled with specs like 22,000+ RPM, 65+ power and 100+ torque. That should have plenty of bling...
Still Bill is offline
Old 03-23-2004, 08:10 AM
Trader Rating: 31 (100%+)
Winner of last weeks race ran a p2k2. Lex and I when we won ran Monster stocks.I would suggest the p2k2 .You dont need High rpm at this particular track.Monsters at this particular track need to be geared perfect or your slow.They dont inherantly have alot of torque.The p2k2 is a good balance between the 2. Just buy the motor from Rctech.They will take care of you.No need for all the fancy online motors when you can support them and there race program by buying from them.They have some highly tuned monster if yu must though.Birdman motors have been fast and they sell them to.
racenut123 is offline
Old 03-23-2004, 08:12 AM
Regional Moderator
Racer_Chick's Avatar
I've tried a bunch of different stock motors (P2k, P2k2, Core, Green Machine...) and I like the monster the best of all of them. I have some of the ones straight from trinity, and there's also a crc one, a fantom, and a code red in our motor box. I've run them on big tracks, little tracks, oval tracks, and carpet and they work great on everything for me. I've never run the MVP, although I did consider it, but I got the monster instead. That one is probably the best out there right now, IMO.
Racer_Chick is offline
Old 03-23-2004, 11:57 AM
edseb's Avatar
I've tried many stock motors, including the P2K2, Monster Stock Pro, Slot Machine, Core, Epic Binary Pro Stock, etc. The Epic is super good, has great RPM, not as much torque and not legal for ROAR sanctioned races. The Monbster stock pro is good any way you slice it. If you are just starting out, you won't notice the slight variations betweent he motors of this caliber.
edseb is offline
Old 03-23-2004, 12:07 PM
Monster stock. Plain and Simple The best stock motor There is.Almost anything you throw At it will React good. binaries are More Picky, will work good if you have good brushes and spring combination. Monsters have Lots of Torque Also. Binaries have lots of RPM but take Long time to Get To Max RPM. IMO MOnster is the best.
Source: Rc anonymous
True R/C Racing is offline
Old 03-23-2004, 12:50 PM
Monster is my choice
the Monsters i build are usually quite torquey but it depends on gearing also
R/C Anonymous is offline
Old 03-23-2004, 01:07 PM
Can You gear For Torque? I dont think. If you want speed out of a Monster gear it toward Max Speed. and you will have Torque and good speed. But im 99%wrong so dont take my Word
Old 03-23-2004, 01:12 PM
i thought i was wrong once but i was wrong
Old 03-23-2004, 01:20 PM
Trader Rating: 24 (100%+)
Not a real fan of Trinity motors but the P2K and P2K2 will do really well on the track you described. The MVP can be a great motor but it takes a little work. Although not ROAR legal yet ( should be soon) the Integy motors are worth looking at. www.integy.com
Take a look at their stock brush selection and also Team Paradigm's website for brush info. You can get a good idea for what "cuts" effect torque or rpm. One of the strongest stock motors I ran on a very small ( 40x40) technical track was the Peak Spitfire. Now known as the Hellfire.
Evoracer is offline
Old 03-23-2004, 01:35 PM
Tech Legend
Cain's Avatar
i read somewhere that the hellfire responds similar to the MVP when you tune it. If anyone has it, maybe try it out with the trimmed brushes.
I have a P2K Pro motor that had a basically new comm. Broke it in with some endurance brushes from Peak and will see how it goes. I figure it won't be all out powerful but this will be my practice motor anyway so I am not too concerned. I will post what I think between that and my tuned up MVP.
I have heard bad things about the ROM motors and the binaries aren't legal at alot of tracks , not at all at ROAR tracks.
My luck with trinity stuff hasn't been good so I am biased towards anything else
Cain is offline
Old 03-23-2004, 01:59 PM
TimPotter's Avatar
Trader Rating: 14 (100%+)
Personally the monster has proven to be faster on all types of tracks for me. Get the gearing right and your good to go.
TimPotter is offline
