Soldering iron tip pits. >
Old 03-22-2004, 06:54 AM
  #16
komkit's Avatar
Also you can put this Catalog #: 272-707 lamp
After the switch before the iron. You can see the lamp dim when you flip the switch to the half-wave and full bright with full-wave mode.
komkit is offline
Old 03-22-2004, 06:55 AM
  #17
fatdoggy's Avatar
Sounds good. I'll give it a shot.
cheers.
fatdoggy is offline
Old 03-22-2004, 06:59 AM
  #18
fatdoggy's Avatar
I'll stick in the lamp too, good idea.
fatdoggy is offline
Old 03-22-2004, 07:00 AM
  #19
komkit's Avatar
Sure, if you need a tips replacement check out www.contacteast.com
komkit is offline
Old 03-22-2004, 10:39 AM
  #20
I'm glad I am not the only one with this problem.
ratcar is offline
