Brushes
I want to cut the trailing edge of my new brushes, i have the cut off bit ready, but how much do i cut off?
...and how do you do this neatly...?
Huh? Bit? You can use a file to cut off 1mm - 3mm, thats all your really need.
the thing i'm wondering, is a a straight diagnal, or do you cut the entire brush down, so what is the lenght of it to start/to end(after cut)
i only cut my brushes for 1/12th scale...is this for your sedan?....depending on the comm size in sedan is usually if i play with the edges of the brush or not
thanks, that helped huge, i think i'll give it a try in practice tonite, i bought so many brushes on saturday i can experiment alot. Now i just gotta figure out which way the motor turns, i think it's clockwise.
pro3 its clockwise if your looking at it from the endbell side
Originally posted by AzNDRAGster Huh? Bit? You can use a file to cut off 1mm - 3mm, thats all your really need. |
