Old 03-21-2004, 04:52 PM   #1
Brandon R's Avatar
Default Battery weight
What do you think is the battery weight difference in grams in a 2000-3000mah to a 3300mah? I was gonna get some 2400's to start with a get used to the car and get it set up right but if the weight is off i will just get 3300's
Brandon R is offline   Reply With Quote
Old 03-21-2004, 06:26 PM   #2
Tek Nickal's Avatar
I find the GPs are the heaviest batteries out there.
Tek Nickal is offline   Reply With Quote
Old 03-21-2004, 06:50 PM   #3
Brandon R's Avatar
so i should just get some 3300's.....ya know where to get some cheap ass ones?
Old 03-21-2004, 07:24 PM   #4
Ebay
provided you trust the seller
Ghosst is offline   Reply With Quote
Old 03-21-2004, 07:26 PM   #5
Tek Nickal's Avatar
Make sure you get good matched ones. . . . but why do you need the weight?
Old 03-21-2004, 07:27 PM   #6
Brandon R's Avatar
i was gonna get some 2400's just to play with...found some for 16 bucks...im not gonna set car up with the 2400's and have to redo it for a different weight battery
Old 03-21-2004, 07:44 PM   #7
Tek Nickal's Avatar
Why do you need your car so balenced if your just going to play around with it?
Old 03-21-2004, 08:19 PM   #8
Still Bill's Avatar
Must be serious 'play'...he, he...
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 03-21-2004, 08:37 PM   #9
fatdoggy's Avatar
R/C Tech Charter Subscriber
Mathced 2400's still are fine for qualifiers. I run smc 2400's for qualifiers use a zx 3300's for the main. I charge my 2400's at 7amp charge with a 10-14mv/cell cutoff and keep them dumped out through the week(use solder on dischargers) and they work great. 3300's go for $30 a matched pack at www.zxracing.com , you won't find them cheaper. Even the unmatched packs else where cost more.
fatdoggy is offline   Reply With Quote
Old 03-21-2004, 10:56 PM   #10
Brandon R's Avatar
haha im talkin play as in get used to a touring car....jumping from gas truck to elec touring is a VERY big jump i hear....after a month or so i will start racing serious. I am a perfectionist and the car will be balaced within a tenth of a gram and i will practice with the car setup like it would be for racing. Thats just my style though and have been doing it for many many years in real racing
Old 03-22-2004, 12:19 AM   #11
Speedie's Avatar
Brandon yout thinking is right on. The difference between the 3000 packs I have and the 3300 is about 40 grams. Fukuyama and Hurricane offer deals on 12 and 18 cell blocks that are pretty reaonable for practice packs. The Fukuyamas would be good enough to practice with and start racing with. If your going to spend money on cells you might as well buy something that you will get more use out of.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 03-22-2004, 12:40 AM   #12
Brandon R's Avatar
thanks speedie....i looked on ebay and found a place that had 24 for 100bucks so im gonna snatch some up and play around with em
Old 03-22-2004, 12:50 AM   #13
Speedie's Avatar
Thats a good deal. your right on track balance is very important. Youll notice the difference when you set tweak.
Old 03-22-2004, 01:42 AM   #14
Brandon R's Avatar
you might think this is cool.... on our real race car..2400lbs the weight was 49.8 front 50.2 rear and 50.1 left and 49.9
Old 03-22-2004, 01:51 AM   #15
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Brandon - You might be interested in this.. Longacre has a RC version of the Computerscales. Not cheap though, in the mid to high $800 range.
Our cars are 3,000lbs w/driver.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
nimh battery capacity vs weight and 1/12th benben10 Electric On-Road 13 08-05-2008 03:12 PM
4200 BATTERY WEIGHT pink_sleeve Electric On-Road 8 10-23-2007 09:06 AM
4200 BATTERY WEIGHT pink_sleeve Electric Off-Road 3 10-19-2007 04:49 PM
Weight of a HPI R40 jdcarbon Electric On-Road 2 04-24-2006 01:30 PM
Weight? SPC Racing Electric On-Road 2 03-18-2004 04:27 PM
