Spring rate too soft? >
Old 01-20-2010, 04:50 PM
Default Spring rate too soft?
Can having too soft a spring rate make a TC spin out? I've been having trouble locking the rear end of my losi jrxsPro to the track. Finally decided to re-check my springs.....the fronts are "correct" AE blue, but the rears were wrong. i found out that they were HPI silvers instead of AE silvers. The HPI springs are rated at 8 lbs instead of a heavier wt. I just made up some BK brackets today and they're go on the car after i get the kids to bed. thanx in advance.
nomaak is offline
Old 01-20-2010, 05:07 PM
stiltskin's Avatar
Trader Rating: 103 (100%+)
If the rear is rolling too much, the chassis may drag on the track and take the pressure off of the tire. That would cause you to spin out. If you're running carpet and this is happening, you should see some gunk build-up on the outside edge of the rear of the chassis.
stiltskin is offline
Old 01-20-2010, 05:25 PM
thanks stiltskin...i'm running on an older grade parking lot. it's kinda on the ruff and gritty side. with my past 3 racecars i've managed to get a comfortable set-up in one or two test days. but not this car! i've been at it for a month now! i'm not that big a fan of rubber tyre racing but i aint new to chassis set-up eigther..... but this losi is a hard beast to get comfortable on asphalt. (unless you're at a big race and the track has been prepped for greater traction).
nomaak is offline
Old 01-21-2010, 06:04 AM
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
try a heavier weight oil in all 4 shocks.
dontfeelcold is offline
Old 01-21-2010, 06:29 AM
M-Technic's Avatar
Trader Rating: 15 (100%+)
HPI silvers are actually stiffer than AE silvers. HPI silvers are 17lb springs and AE silvers are 14.5lb springs.
M-Technic is offline
Old 01-21-2010, 06:32 AM
trerc's Avatar
Trader Rating: 89 (100%+)
Yep ^^^
trerc is offline
Old 01-21-2010, 04:18 PM
wow...their web site says they're 8lbs. (look up the spring rate chart)
hpiracing.com/graphics/instr/I-6751-2-V9-color.jpg
dontfeelcold...you could be right. i'm running 30wt in the front & 25wt in the rear. pink pistons all around. factory "BK" arms fr/ homemade BK brackets Rr.
nomaak is offline
Old 01-21-2010, 04:37 PM
trerc's Avatar
Ahh, I assumed you meant the Pro 4 springs.. Sorry
trerc is offline
Old 01-21-2010, 07:23 PM
no prob tre. if i could get these to work then i sure would!!! MY lhs has a bunch of them.
nomaak is offline
Old 01-21-2010, 10:58 PM
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
springs control how the weight transfers, i would start with correct tires and maybe add a little rear toe-ins.
Tag is offline
Old 01-22-2010, 07:34 PM
thanks tag.....i got a couple pair of losi springs so i can bring the shock towers down to the lower mount. losi made this car a losi "exclusive" IMO. other words....it's parts dont play well with other manufacturers.
we haven't had a dry day here all week. soon as it dries i'm headed back out with different pistons. have some 6-7-7's and sum 6-6-7's in mind.
nomaak is offline
