Homemade Board Me and my Dad made
#16
Its cool but, Whos Going to work on there car in the Dark? Not trying be a Smarta$$ or anything Im just Curious, or am i Not Gettin the point?
#17
Are you trying to make the board act as a Prism and send all the light through it? That would be cool if you made it work, does it help at all when the room light is ON?
#19
it's just to have 'trick' equipment in the pits. the blue light doesn't help at all....at dim tracks it looks pretty trick. even at tracks that are lit decently you can still see the blue light...i'm working on another verison that has a cleaner design.
basically it was built for fun....same reason people are putting lighted computer fans in chargers and other r/c items...doesn't help performance...but looks trick
#20
#22
#23
That gives me an idea. Anyone ever use a light table to work on. We had them in a drafting class I had in high school. Just frosted glass over florecent lights
i'd route a channel in the bottom for the light rope to fit into. that would look cool.
hopefully i'll have v.2 finished soon.
#25
Location: Pacifica, California OR Clearlake Oaks, California
forgive me for being such a noob, but how exactly do you use a setup board, I get what it is for it's the how I don't get.
#27
Look at it this way, try setting your ride height on an un-even carpet, not very effective eh? But have a super flat surface such as this and you know its correct. Can also check for tweak.
#28
Originally posted by AWOLsoldier
pops, where'd you get the foam from?
Mine is basically the same stuff that the Hobby Shops sell for protecting Receivers. 'McMaster Carr' just has it available in larger size sheets.
You could even use Cork if you wanted. All I did was laminate the Foam to one side of the Glass with some Spray Adhesive then trim the excess from the edges.
#29
pops...what industry you in? We use mcmaster alot and also small parts down in florida....you ever got prices on body clips from either of those places...i know small parts are 100 for little over 2 bucks and motor screws are about the same
#30
