Old 04-12-2004, 03:34 PM   #121
Registered User
The hottest part is inner 4: - (+ - + -) +. outter 2 are about 10F degrees less.
Aku-Man is offline   Reply With Quote
Old 04-12-2004, 03:43 PM   #122
Registered User
Maybe I just have to buy other charger to try out.
Old 04-13-2004, 02:29 AM   #123
Send a message via ICQ to rcnewb2004
Being the newb that I am, if you have a side-by-side pack, you can try to disassembling your pack and cycle your cells one by one and check for a weak one.
It seems to be that there maybe a bad cell somewhere, or a short inside your pack.
I had a defective cell in my sanyo3300 and the heat got so crazy, the wrapping around the cell melted.
Also, what's the internal resistance reading on your cells during a discharge?
If your IR is high something is wrong with your cells.
rcnewb2004 is offline   Reply With Quote
Old 04-13-2004, 02:30 AM   #124
sosidge's Avatar
I doubt your charger is the issue.
It sounds like unequalized/bad cells.
Try discharging your packs on a tray before you charge them up next. If you don't have a tray, try a trickle charge (0.3A say, with trickle set to "On").
If you're still not getting good charge results, try cycling each cell individually to see how they match up.
Oh, and make sure trickle is "Off" when fast-charging NiMH's.
Old 04-13-2004, 02:33 AM   #125
I hope my prev newbish advice don't screw you over Aku.
My sanyo2000 nicds seem to charge with less capacity every time... anyone know what's wrong?
(I can't afford an equalizing tray at the moment)
But I still dont' think not using an equalizing tray has this big of an effect?? EVERY TIME I charge my cells, I find it charges to less capacity?????????!!
Old 04-13-2004, 05:00 AM   #126
sosidge's Avatar
Equalizing tray does have a big effect, especially with NiCd's.
If NiCd's aren't fully discharged, they develop a "memory", and over time will end up with less capacity.
Odd that you are getting less capacity every time - discharging is important (use the CDC, if you don't want to get a tray yet) - as long as the cells still get warm under charge, they should be fully charged.
Old 04-13-2004, 11:52 AM   #127
fatdoggy's Avatar
R/C Tech Charter Subscriber
I still run nicd's and I've never use an equalizing tray. My 2400's pull in 2600mah. I charge them once a week and then discharge and solder in dischargers to make sure their kept empty.
http://www2.towerhobbies.com/cgi-bin...?&I=LXJ282&P=7
With nicd's the voltage jumps up very quickly as soon as you stop discharging. I solder on the dischargers, discharge the pack at 20 amps, then 5 amps, 2 amps then .1 amps. This makes sure they are completely brought down. After a week the light will be either dead or very dim, which is what you want.
If you are charging them back to back then you will see a capacity drop, this is normal.
fatdoggy is offline   Reply With Quote
Old 04-13-2004, 02:24 PM   #128
Cole Trickle's Avatar
Seems like the main benefit is to drain the packs. But: An equalizer will do it more safely, since it eliminate the risk of cell reversal. And the EQ will keep the cells synchronized, well, at least at the buttom end. There migt be a single cell that never get fully charged
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 04-13-2004, 02:28 PM   #129
I'll second this.
In addition, by cycling each cell individually, you get the cells equalized. It take longer time, but if you aint got a tray, this can be a free alternative.
By the way, I've tried trickle charge a few times, and the pack was quite slow/lazy the first couple of runs afterwars, so I would prefer the individual cell cycle instead.
Old 04-13-2004, 02:33 PM   #130
Registered User
Well, I'm tired of this. I'm going to sell my CDC6.0 B2(just bought it ) and get a quantum or orion.
Anyway, thanks for the help guys.
Old 04-13-2004, 02:54 PM   #131
fatdoggy's Avatar
Cole Trickle - I don't disagree that equalizing it the better way of keeping your cells in good condition.
Old 04-13-2004, 03:23 PM   #132
Aku, before you decide to spend another $200 try charging other batteries on your CDC?? Or, you can take it in for warranty?? I don't know about you, but I dont' have a lot of $200 to spend.
I think everyone that's posted in this section will tell you the CDC is a good charger. So I REALLY think you should try all the alternatives before you do this. Cause I won't sell my CDC for anything out there at the same price level.
And with regards to this:
"If you are charging them back to back then you will see a capacity drop, this is normal."
Fatdoggy, How can i fix the capacity drop? By cycling my pack again?
Thx all.
Old 04-13-2004, 06:23 PM   #133
fatdoggy's Avatar
Generally for nicd's the first charge of the day will yeild the most capacity and punch. Every charge after that you'll drop capacity and punch. Hence why I only run my nicd's once a day. There really is nothing you can do about it.
Old 04-13-2004, 07:56 PM   #134
Does the capacity come back if I let it rest?
Old 04-13-2004, 08:31 PM   #135
fatdoggy's Avatar
Yes if you let them rest and keep it dumped the capacity comes back. Nimh cells really are easier to deal with.
Integy INDI 16x5v6/Eagle CDC ver6.0B silverM3 R/C Items: For Sale/Trade 1 07-29-2006 07:36 PM
Indi 16x5v6 Charger Pro Parts R/C Items: For Sale/Trade 8 02-19-2005 07:29 PM
***TWO Integy/Eagle/CDC 16x5v6 Chargers*** =MisFitz= NuKe R/C Items: For Sale/Trade 4 02-13-2005 08:45 PM
Eagle CDC V6.0B/Integy 16x5v6 sosidge Electric On-Road 7 10-18-2003 04:25 PM
Indi 16x5v6 AC/DC lilshortyc3 Electric On-Road 110 02-13-2003 07:35 AM
