INDI 16X5v6 / Eagle CDC 6 >
Old 07-01-2006, 01:12 PM
  #436
ah_DaN's Avatar
is there anyway I can fix it myself?
Because I am currently in Canada and I bought my charger in HK.
Can I send it to Integy instead of Eagle racing?
ah_DaN is offline
Old 07-04-2006, 09:18 PM
  #437
ah_DaN's Avatar
bump for help please!!
ah_DaN is offline
Old 07-04-2006, 11:22 PM
  #438
XrayFK's Avatar
Are a trained electrician of sorts? If not, then no, you won't be able to fix it yourself. You could always try a different PS, just in case.
XrayFK is offline
Old 07-11-2006, 06:40 AM
  #439
29TC's Avatar
A slight deviation from the 16x5V6.
Has anyone noticed that the 16X512 charger is in stock at integy?
Anyone seen one of these at the pits? So far, I know is chargers like the 16X8V6 but has no discharger function
All I need to know is if the display is backlit or not? If its backlit, I will get one.
29TC is offline
Old 07-11-2006, 09:24 AM
  #440
rc-zombies's Avatar
yes it's identicle to the 16x8v6 but without the built in power supply.
like all new Integy chargers recently released..it should have a backlit display.
still no memory slots.
It's also cheaper at Tower and instock as well...
the replacement for the 16x5v6 / cdc 6.0 is the new 16x908/cdc7.0 climate controlled charger. should be out in about a month.
rc-zombies is offline
Old 09-29-2007, 05:56 PM
  #441
nikkiesteban's Avatar
hi guys, Anyone figured out why it doesn't charge? my cdc 6.0/b also stays at 0mah when charging but when discharging it's working.. it works only as a discharger now. I want to use it as a backup charger.
nikkiesteban is offline
Old 09-30-2007, 01:50 AM
  #442
ah_DaN's Avatar
Same thing happened to my CDC 6.0. Mine have been sitting there useless collecting dust.
I guess its cheaper to buy another charger than to send them back and fix it.
ah_DaN is offline
