Old 03-25-2004, 07:24 AM   #31
Cole Trickle's Avatar
It do have four user selectable charge modes: Normal, partial, fuzzy logic (discharge followed by a normal charge) and boosting. The last one is for packs which is fully charged, but has cooled down. A short (partial) discharge, followed by a normal charge until peak, warm up the pack again. This aint programmable, when its' about amount of discharge, discharge rate and charge rate. I believe the charger have a pre-defined program, which is adjusted to the user-choosen capacity.
Pricing? Import duties and exchange rates ! I'm in europe, which probably help LRP, while making the Eagle more expensive due to import duties. The Pulsar cost 1.800 DKR, which equals 286 USD. But the exchange rate for USD is in our advance for the moment, at least when we buy US products
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 03-25-2004, 08:21 AM   #32
By the way, the manual can be found here .
Old 03-25-2004, 08:55 AM   #33
sosidge's Avatar
Re: 4-cell packs - the charger is limited in the charge rate for lower numbers of cells.
4-cells will charge at a maximum of 4.7A!
Old 03-25-2004, 09:16 AM   #34
CRASH's Avatar
Trader Rating: 26 (100%+)
Thanks for the info.
CRASH is offline   Reply With Quote
Old 03-25-2004, 12:03 PM   #35
I race oval and charge 4 cell packs all the time. If you have the Eagle power supply, you can lower the charger's input voltage to 10.2V to 10.4V and charge 4 cell pack at high current (6A+). The 4.5A or 5A current limit only appears if the input voltage is higher. The unit can charge up to 16V or 17V even with a 10V input, it seems to have a step-up circuit built-in.
RickyIS300 is offline   Reply With Quote
Old 03-25-2004, 01:08 PM   #36
etzkev's Avatar
Send a message via AIM to etzkev
Thanks for all your help guys! This is really a nice charger. Now I am surely going to get it.
Thanks,
etzkev
etzkev is offline   Reply With Quote
Old 03-25-2004, 11:51 PM   #37
RickyIS3000; This is definately good news. Because my modified computer power supply deliver 11,6-11,7 volt, when there's a load. So I was a little worried if I had to upgrade to something with a better voltage output, when I need to charge 8 cells packs...
Ricky and sosidge; Where do you guys have this info from, is it simply experience?
Old 03-26-2004, 03:40 AM   #38
sosidge's Avatar
Experience... and the manual! The charge limits are mentioned in an addenda.
Old 03-26-2004, 04:27 AM   #39
Sounds good about the manual - the one I've downloaded is in a bad quality regarding view. My charger should arrive by post today or maybe tomorrow, I look forward to it
Old 03-26-2004, 04:33 AM   #40
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
Cole, I hear ya on the manual.....
Once you use the charger a couple times, it is easy to use from then on out....
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 03-26-2004, 04:57 AM   #41
The most annoying about the downloaded manual, is the graphics quality, so it's hard to read. It's probably alright, if you got a US paper format printer, but with european paper sizes, it will be resized with bad graphics quality as a result. So I look forward to get the real manual...
But the way the manual is structured aint too good either - that much I can see...
Old 03-29-2004, 03:37 AM   #42
Charger has arrived, yeeeha
Sosidge, I cant find the part with the limitations in the manual. Is there different versions?
I've also noticed that the charger wont start charging, if the voltage is too low. Do it calculate the proper minimum voltage based on how many cells is entered?
Old 03-29-2004, 07:58 AM   #43
fatdoggy's Avatar
Sounds like they screwed with the v6 series of chargers too much. The v5's will charge from completely dumped. Just hook up two 6 cell packs + to + and - to - and charge them for a few seconds and it should bring the voltage up enough to charge them seperately.
fatdoggy is offline   Reply With Quote
Old 03-29-2004, 11:46 AM   #44
I love the CDC so much, the best part of the charger is it's 20A discharge with information, this let you know your battery's actual discharge condition, there no other charger can do at this price, I use it to match my battery for practice and it did so close to matched brand cell.
rranger is offline   Reply With Quote
Old 03-30-2004, 02:25 AM   #45
Naahhh, I dont think they screwed up... The charger try to put in a charge of 0,11 amps for a couple of minutes, and if the pack voltage aint raised at that point, there comes a message that says something like: Error, voltage too low. Please note, I've only seen this message with old (abused!) packs, which have been stored discharged for several weeks.
I boost these packs with a PS I have; 7,2 volt and 1 amp for a few seconds.
Overall, I really like this charger. RRanger said it good. And in general the features are good and as sosidge said, it charges almost any pack and it never false peaks. Even not on very abused packs... The fans are noisy though and the beep tones are very high. It would be nice if the tones could be shut of.
Integy INDI 16x5v6/Eagle CDC ver6.0B silverM3 R/C Items: For Sale/Trade 1 07-29-2006 07:36 PM
Indi 16x5v6 Charger Pro Parts R/C Items: For Sale/Trade 8 02-19-2005 07:29 PM
***TWO Integy/Eagle/CDC 16x5v6 Chargers*** =MisFitz= NuKe R/C Items: For Sale/Trade 4 02-13-2005 08:45 PM
Eagle CDC V6.0B/Integy 16x5v6 sosidge Electric On-Road 7 10-18-2003 04:25 PM
Indi 16x5v6 AC/DC lilshortyc3 Electric On-Road 110 02-13-2003 07:35 AM
