Old 08-15-2004, 06:00 PM   #376
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Yep...well, I did have it, and I also used to have a 16x7 (the one before the V6 software). Anyways, what did you need to know? Or did you just want to know if someone had one? lol.
=MisFitz= NuKe is offline   Reply With Quote
Old 08-16-2004, 02:19 AM   #377
For those CDC 6.0B owners, could anybody tell me how to calibrate the voltage detection circuitry. I have two CDC6.0B, however, they give significant voltage readings difference for the same pack.
kennykay is offline   Reply With Quote
Old 08-16-2004, 04:38 AM   #378
MartinSorlie's Avatar
I would like to know if there are any big differences I should know about. And if anyone has had problems with it, or the power supply itself....
Martin Sørlie, 1985, R/C since 1995.
TLR - Spektrum
www.teamsmallsize.com
MartinSorlie is offline   Reply With Quote
Old 08-16-2004, 10:34 AM   #379
sosidge's Avatar
I don't believe they can be user-calibrated.
Old 08-16-2004, 12:36 PM   #380
no, everything is fine. It is the exact same as the popular 16x5v6/CDC6.0B. The power supply is fine, it is a 14 amp power supply, enough to run a second charger off of. The power supply that is inside it is the same as the Silver eagle 14 amp PS available on integy.com
Old 08-16-2004, 03:37 PM   #381
So is there an outlet for a second charger?
TLR - Spektrum
Old 08-16-2004, 06:04 PM   #382
well, there are two female ends of a bananaplug to plug a cord that is included with the charger into...
Old 08-18-2004, 05:28 AM   #383
Cole Trickle's Avatar
About the CDC V6.0 B based chargers; They push the cells harder. So the packs will be quite warm after a charge. Ensure the ambient temperature aint too high and also use conservative cut off settings.
The good thing about it, is it's great for stock racing
Mine works good with GP3300. But with my old and abused Sanyo 3000HV, the pack allways get too hot. I dont know if it's because the pack is damaged or the charger simply cant handle this pack...
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 08-20-2004, 07:45 AM   #384
bballer's Avatar
I got my charger a week ago, and can i say, wow, this thing is great!! One question though. I have a pack of fukuyama 3300s that i tried to charge on the boosting charge. The pack was cool, and everything was fine until the mah went over 3600 and i quickly turned it off !! Is there something wrong or does the boosting charge do that. The batts still work and all that, but i don't want them to explode or anything. Thanks
bballer is offline   Reply With Quote
Old 08-20-2004, 09:33 AM   #385
sosidge's Avatar
The boosting charge should only be used on cells that have already been charged - e.g. if you had to charge the night before your race, and you want to freshen them up before putting them in the car.
You'll find that GP's will take over 4000mAh charge from equalised flat, so you don't need to worry if the capacity reads 3600 while charging a discharged pack.
Old 08-20-2004, 11:38 AM   #386
bballer's Avatar
Old 08-25-2004, 04:55 AM   #387
Trader Rating: 69 (100%+)
difference between B and B2
i purchased a CDC about a couple of years ago and it says "version 6.0/B" on startup. recently, i got a used CDC and it displays "version 6.0/B2" externally, this is the same charger. but would you guys know if the software has been changed? are there added features? thanks for any info
marvi is offline   Reply With Quote
Old 08-26-2004, 07:35 AM   #388
TTT any info on my previous question - difference b/w version B and version B2?
anyway, i tried both chargers at the same time this afternoon. i have 6 packs of 3300 batteries (3 packs eagle zapped unmatched packs 2nd gen GPs and 3 packs trinity matched packs 1st gen GPs). i charged the 1st 3 packs on my 1st CDC and the other packs on my 2nd CDC.
i used the boosting function and the freaky thing is, 5 out of the 6 batts peaked at exactly the same time - 30:54. 1 battery peaked at 29:54 i wasnt able to record the mah and peak voltages but im sure they were all different from one another. they just shared the same exact charging time
Old 09-23-2004, 08:03 PM   #389
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
i had the CDC v6 for a year now,
just wondering why the sanyo 3300 unmatch does not have the punch like the GP3300 unmatch>?
They both are at the same age.and charge at 6amp ( running stock motors) and both equalized after each run.
Sanyo end charge at 3600nimh <---sunday drive
GP end charge at 3800nimh <--- more punchy
Maybe some of you guys have some tips how to save my sanyos.
Should i lower the amp?
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 09-23-2004, 08:10 PM   #390
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
Check IR on the Sanyo 3300's....
The ones I had went sky high....
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Integy INDI 16x5v6/Eagle CDC ver6.0B silverM3 R/C Items: For Sale/Trade 1 07-29-2006 07:36 PM
Indi 16x5v6 Charger Pro Parts R/C Items: For Sale/Trade 8 02-19-2005 07:29 PM
***TWO Integy/Eagle/CDC 16x5v6 Chargers*** =MisFitz= NuKe R/C Items: For Sale/Trade 4 02-13-2005 08:45 PM
Eagle CDC V6.0B/Integy 16x5v6 sosidge Electric On-Road 7 10-18-2003 04:25 PM
Indi 16x5v6 AC/DC lilshortyc3 Electric On-Road 110 02-13-2003 07:35 AM
