Old 08-03-2004, 10:35 AM   #346
Send a message via ICQ to rcnewb2004
Unhappy
oh, cole, if i dont' need a 20 amp discharge, i should store them
when i bring them out again then
equalize-->condition--->charge full?
(just making sure i will treat my cells right the next time)
still wondering, which would would you guys pick? peak surikarn edition or the hara from team orion?
or at least suggest me a website that sells these motors and are INSTOCK?
even if i have good cells, no motor to use them... then.... i am still stuck in a rut....
rcnewb2004 is offline   Reply With Quote
Old 08-03-2004, 01:19 PM   #347
Cole Trickle's Avatar
Originally posted by rcnewb2004
sosdige: my packs aren't dead flat... just 0.9v/cell equalized.... a second discharge won't hurt it, cause if it was below the cutoff, it just won't discharge right?
Not excatly; The voltage raises, whil the pack is unloaded. This allows the discharger to take out some extra mAH, before it cut off again.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 08-03-2004, 01:20 PM   #348
Precisely.
Old 08-03-2004, 04:42 PM   #349
how long should i wait after the load is removed from the batteries?? before I discharge at 20amps?
Old 08-03-2004, 08:48 PM   #350
bballer's Avatar
Hey all, now i see you're talking about an equalizer, what is that?? I am getting a 16x5v6, and will i need an equalizer too?? Thanks for answering the stupid question
bballer is offline   Reply With Quote
Old 08-03-2004, 10:12 PM   #351
Well, each battery pack consists of a number of cells (individual little batteries if you will). Most commonly six.
Because of each cell's difference in capacity, IR, and other things, when u dump your pack, there maybe some power left in some cells where as other ones may already be well drained.
An equalizer, will just discharge each cell individually to ensure that all your cells are discharged to the same level.
It helps preserve the capacity of the pack as a whole and improves punch. At least that's what I have heard but like my name, I am just a newb, so don't quote me on these things. cause that's just from what I heard, and felt on my own car after using the equalizer.
Old 08-04-2004, 01:17 AM   #352
Default dropind out
Hi all i have just noticed when charging with my 6/b that the
amps on the screen turn off and on is ok ???? thanks Jeff
jeff19 is offline   Reply With Quote
Old 08-04-2004, 01:37 AM   #353
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
Anybody got the INDI 16x3v6? I just got one and so far I love it ; the only thing is , is that the seconds counter is WAAYYY off, showing me something like 1450s <-----
I think I'm going to contact Integy about this and see what gives.
ALL in ALL, A GREAT CHARGER THOUGH
- JayBee
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-04-2004, 01:38 AM   #354
sosidge's Avatar
Default Re: dropind out
The charger does pause for a couple of seconds every minute, it's normal, don't worry!
Old 08-04-2004, 01:52 AM   #355
Send a message via AIM to micros_rock
I have the 16x5v6 and I love it. If it helps anyone, this is what i do with my packs:
1) After a race/run i discharge the pack at 20A down to 0.8v/cell (not adjustable, oh well)
2) The next day after the race, I put the packs on my Real Time tray and bring all the cells down to 0.05v. Then I partial charge them at 30% to store them until the next race.
3) Two days before the race, I cycle the packs once and tray them again.
4) Before race day I charge them back up @6A with 5mv/cell detect. 5-10 min before I race the pack, I use the boost function on the pack.
Disclaimer (): I'm not saying this is the way to do things, just how I do things.
micros_rock is offline   Reply With Quote
Old 08-04-2004, 05:23 AM   #356
Micros_rocks:
I would definately not cycle the batts like this (okay, maybe if they have been stored for 3 months...)
A pack have a limited number of charges / discharges. Some people only count on 40 good runs... So cycling like this, means you only have half charges on the track....
You'll get better performance, if you charge just before the race, instead of charging at home and then boosting.
Also, I wouldnt equalize them below 0,9 volt pr. cell.
Old 08-04-2004, 09:33 AM   #357
bballer's Avatar
Is an equalizer ABSOUTLELY necessary?? Will it dramatically improve battery punch and life or is it not that needed with the 16x5v6. How much does a good one cost? Thanks
Old 08-04-2004, 12:39 PM   #358
It will improve punch and it'll also ensure that the batteries last longer. A guy at our club recently got a equalizer. He's the kind of that always buy the best, he can get. He got matched Orion cells - he was quite surprised with the equalizer...
Some of the best are the Rayspeed and the Indi SP Saddle Relay Cut-off Discharger 5A . The Novak is also good, but too expensive at my opinion, compared with the before mentioned; Basically, they do the same.
For budget guys like me, the Robitronic is very good: AUto cut off at 0,8 volt, 1 amp discharge rate and control LED's to ensure all batteries have contact. The price is 30 euro. I dont think Robitronic is represented on the US market, but you can either order it from Europe or find something similar elsewhere.
Old 08-04-2004, 12:50 PM   #359
Cole: how long should i wait after i remove the batteries from my car before I discharge at 20amps?
That's the thing i dislike about the rayspeed, I have no clue if the contact is any good between the eqaulizer and the cells. Trying to draw 5A out of a "pin head"... is still not a great thing to do if the pack is like half full.
bballer: A rayspeed will cost u at least a good $60 USD. (That's about how much I got mine anyway)
Its not ABSOLUTELY necessary. If u use crappy cells, don't bother. But if u ever plan to get some good cells, get a equalizer tray first. (I made that mistake, and I turned my good cells into crap now).
Discharger trays are fun. Its almost like a youth tonic to old cells and vitamins to a new one. It just keeps everything healthy.
Old 08-04-2004, 01:11 PM   #360
I've tried it on a old pack of Sanyo 2000 NiCd, which had not been equalized for approx 2 years. The pack waked up and was fun to use. It still was a cheap pack, but it was better than anytime before.
Each time I get a new pack, I equalize it before tyhe first charge. It works.
Integy INDI 16x5v6/Eagle CDC ver6.0B silverM3 R/C Items: For Sale/Trade 1 07-29-2006 07:36 PM
Indi 16x5v6 Charger Pro Parts R/C Items: For Sale/Trade 8 02-19-2005 07:29 PM
***TWO Integy/Eagle/CDC 16x5v6 Chargers*** =MisFitz= NuKe R/C Items: For Sale/Trade 4 02-13-2005 08:45 PM
Eagle CDC V6.0B/Integy 16x5v6 sosidge Electric On-Road 7 10-18-2003 04:25 PM
Indi 16x5v6 AC/DC lilshortyc3 Electric On-Road 110 02-13-2003 07:35 AM
