Old 04-30-2004, 05:18 AM   #226
Cole Trickle's Avatar
Originally posted by babytoy101
i encoutered this msg. "discharge processing" i think its a msg. to prompt the user when he is discharging a pack at full charge and the halt its discharging job when the charger is too hot! just to show the user "im stoping discharging for a while, its too hot! but i will finish the process" like that!
Could be the explanation... My environment temperature while using the charger is 15-20 degrees celsius and I've never seen those messages.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 04-30-2004, 01:21 PM   #227
Send a message via ICQ to rcnewb2004
i thought it would be like that too... since i do put a low class filter on the fans, (i hate getting crap into my electronics), the fans do have to work a bit harder, and this filter is a pretty good insulator as well. but if it doesn't screw up my numbers, i think its ok.
I will try your trick out tonight Cole. Thx for the advice!
rcnewb2004 is offline   Reply With Quote
Old 05-01-2004, 12:38 PM   #228
I wouldnt put any filter on the fans.
I dont find there's problems with no filers - and if there eventually should be, just clean the fans once in a while.
Old 05-02-2004, 09:24 AM   #229
I tried your discharge method, I find that the Vp is about .1V higher and the Va is .03V lower. But I did get a 250mAh increase in discharge capacity. Also got a 3-5mOhm IR increase.
I don't there there should be a trade off like that? But this occured for both my GP3300 and my Sanyo3300HVs.
Old 05-02-2004, 11:22 AM   #230
Strange. The single cell discharge is similar to using a equalizer with auto cut off. And with an equalizer, almost everybody get lower IR and higher voltage, not the opposite.
Old 05-02-2004, 02:03 PM   #231
hm... i dont' know... amybe i am doing something wrong?
right now, my batteries just went through a 20A discharge, and have been sitting for about 24 hrs....
give me a correct method to test them out? and let me see if its me, or there are other things involved?
Old 05-04-2004, 03:12 AM   #232
I dont know. Maybe you should ask this question in a new thread, with a proper header, this thread may have a mis-guiding header....
Old 05-04-2004, 06:56 PM   #233
rough512's Avatar
Default Quasar Recall
You guys may have seen the Quasar Pro Recall thread...
So are we also affected. Somebody posted that the QP is actually made by Eagle, and Integy CDC is an Eagle in disguise... and if you look hard enough, the CDC is a QP minus the power supply.
anybody had a battery explode on their CDC yet?
rough512 is offline   Reply With Quote
Old 05-04-2004, 09:12 PM   #234
fatdoggy's Avatar
R/C Tech Charter Subscriber
rough512 - I've had my 16x9v5 for a few years now. No problems at all so far, it's been great. If there is a recall for the cdc's I'm sure it will get around.
fatdoggy is offline   Reply With Quote
Old 05-05-2004, 12:17 PM   #235
Default Re: Quasar Recall
Both my CDC and batteries are fine, thanks
The CDC and the QP got different features - like the QP only can take 3 cycles, while the CDC can do 9.
Dont spread bad thoughts about a product, if you aint got any evidence
Old 05-05-2004, 12:37 PM   #236
Baluga's Avatar
If ever you decide to sell your CDC charger, what would be your next charger?
Baluga is offline   Reply With Quote
Old 05-05-2004, 01:03 PM   #237
etzkev's Avatar
Send a message via AIM to etzkev
Default Re: Re: Quasar Recall
The GFX is where it is at! I was planning on getting the 16X5V6 but I decided on the GFX just recently and got it yesterday.
-etzkev
etzkev is offline   Reply With Quote
Old 05-05-2004, 01:07 PM   #238
rc-zombies's Avatar
If I ever get rid of mine...it will be the new Futaba charger...
Old 05-05-2004, 01:12 PM   #239
Send a message via Yahoo to Babylou
How long does it take you guys to charge up your 3300's?? I'm using the 16x5v6 and it takes about 35 min... charging at 5A with 5mv setting.... Jsut wandering.. seems to be a bit long... this was after a complete discharge on an equalizer......
Babylou is offline   Reply With Quote
Old 05-05-2004, 01:20 PM   #240
etzkev's Avatar
babylou, that is just right. Don't worry about that at all.
-etzkev
Integy INDI 16x5v6/Eagle CDC ver6.0B silverM3 R/C Items: For Sale/Trade 1 07-29-2006 07:36 PM
Indi 16x5v6 Charger Pro Parts R/C Items: For Sale/Trade 8 02-19-2005 07:29 PM
***TWO Integy/Eagle/CDC 16x5v6 Chargers*** =MisFitz= NuKe R/C Items: For Sale/Trade 4 02-13-2005 08:45 PM
Eagle CDC V6.0B/Integy 16x5v6 sosidge Electric On-Road 7 10-18-2003 04:25 PM
Indi 16x5v6 AC/DC lilshortyc3 Electric On-Road 110 02-13-2003 07:35 AM
