Old 04-22-2004, 07:29 AM   #166
Send a message via Yahoo to Babylou
If you compare the specs to the 16x9 - it is basically the same charger.... I could not determine the difference between them... Out side of the 16x9 has a power supply option?? I was gonna buy that one but decided to get a high end power supply and have it seperate just in case the charger happens to break or something I still have a power supply... You have to be prepared for the worst.. You just never know when something will fail.
Babylou is offline   Reply With Quote
Old 04-22-2004, 01:35 PM   #167
Cole Trickle's Avatar
The Eagle and the Integy IS the same charger.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 04-22-2004, 02:42 PM   #168
sosidge's Avatar
BUT the 16x9 has a built in power supply - although I also like to keep these thing seperate (just like my hi-fi...)
Old 04-22-2004, 04:00 PM   #169
Default Dont' detect the cells
Hi I have a problem with my CDC ver 6, I setup the charger like before, but when I push Start it says that th'ere's no cell connected. What can go wrong??
martinm is offline   Reply With Quote
Old 04-22-2004, 04:36 PM   #170
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
I posted a question about high ir numbers on the fukuyamaie:starting off at 50+ but by 5 mins into the charge they were down to 35. Not sure what question to ask now so i am going to leave it because they went good enough on the track on wendsday night, so i am still happy chappie,
by the way eagle v6 good charger much nicer then quaser(pooh)
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 04-22-2004, 05:46 PM   #171
IF there is a problem with the integy charger... best to post it on their forums... they can help you better then most...
I have no idea what the CDR V6 is by the way...
Old 04-22-2004, 10:13 PM   #172
babytoy101's Avatar
Default Re: Dont' detect the cells
martinm: check the wire especially the small one, it may be cut or detached fron the aligator clips. check also the battery bars!
good day and happy racin!
babytoy101 is offline   Reply With Quote
Old 04-22-2004, 11:10 PM   #173
rough512's Avatar
I've been wondering about those small wires. They're sensors right?
Why do you need to use separate wires if you're going to attach them to the same clips anyway. Why not just do the sensing using the big wires? just wondering, mine is still warranty-sealed so I can't open the case to take a look.
Hey Babytoy, my Victor can do two things the CDC can't. With the Victor you can alter the charging current up and down during charging; and you can do motor tests too. I haven't tested the motor thing yet. I'll bring it on sunday. The new CDC stays at home.
rough512 is offline   Reply With Quote
Old 04-22-2004, 11:53 PM   #174
Yep, I noticed your question on the Fuku thread, but now it seems like I didnt understood it right.
Batteries IR changes during the charge. It's normal to have a higher initial IR, then lower in the middle part and when the pack begins to peak, the IR will raise again. Thats absolutely normal.
The IR will also change during discharge, but not as much. Often there will be a lower IR during discharge.
So what to do?
As you already noticed, it's track performance that matters.
What I do, is to do one cycle and write the numbers down. Then I can do the same, lets say 3 months later. Now I can compare numbers, to ensure my battery maintenance is proper. I also have clear prove of when the pack wear out.
Hope this helps.
Old 04-22-2004, 11:55 PM   #175
Thing is, that due to the high current, there will be a voltage drop over the thick wires. By using the additional thin wires (which dont carry high current), you get a much more precise voltage sensing.
Old 04-22-2004, 11:56 PM   #176
Default Re: Re: Dont' detect the cells
That's what I would do
Old 04-22-2004, 11:58 PM   #177
My bad, I was thinking of the Integy 16x5v6, which is the same as the Eagle CDC v6.
Old 04-23-2004, 02:30 AM   #178
Ybakoff's Avatar
Hi all.
I have a CDC 16x5 v6 charger.
I have SMC GP3300. 1.174v at 30a Dis.
What amp charge at what mv should I charge at to get the best punch for stock motors.
Thanks Ybakoff
Ybakoff is offline   Reply With Quote
Old 04-23-2004, 02:42 AM   #179
sosidge's Avatar
I think you'll get plenty of performance at 6A charge and 5mV per cell cutoff.
Others may suggest you push the cells harder.
Old 04-23-2004, 02:43 AM   #180
Originally posted by Ybakoff
Hi all.
Thanks Ybakoff
I would simply follow the SMC recommendations , then measure the pack temperature at the point where the charger cut off. The cut-off voltage is a little lower then what Fukuyama recommend resulting in a lower temperature. They need to be at 50-55 degrees celsius to perform good. Maybe a little higher, thats' what Fukuyama recommend, even though I personally havent found any big difference performance wise, between 50 and 60 degrees celsius.
The higher the cut-off voltage, the higher the temperature. So be carefull and monitor the temperature during the first charges.
Integy INDI 16x5v6/Eagle CDC ver6.0B silverM3 R/C Items: For Sale/Trade 1 07-29-2006 07:36 PM
Indi 16x5v6 Charger Pro Parts R/C Items: For Sale/Trade 8 02-19-2005 07:29 PM
***TWO Integy/Eagle/CDC 16x5v6 Chargers*** =MisFitz= NuKe R/C Items: For Sale/Trade 4 02-13-2005 08:45 PM
Eagle CDC V6.0B/Integy 16x5v6 sosidge Electric On-Road 7 10-18-2003 04:25 PM
Indi 16x5v6 AC/DC lilshortyc3 Electric On-Road 110 02-13-2003 07:35 AM
