Old 04-16-2004, 11:41 AM   #151
Send a message via Yahoo to Babylou
it is V6. Brand spankin new.. I assuem I will figure it out.. Not sure how to eve nsave the presets once you get your info for your batteries setup. thanks for the post. I will keep messing with it over the weekend to test...
Babylou is offline   Reply With Quote
Old 04-16-2004, 12:13 PM   #152
Cole Trickle's Avatar
Originally posted by sosidge
It's quite a straightforward charger to use once you realise that the manual makes it seem way more complicated than necessary!
Well spoken, it's one of the worst manuals I've seen in a long time...
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 04-16-2004, 12:17 PM   #153
I've been playing with the boosting charge. My biggest limitation in RC, is tracktime. So I use to charge my oldest practise pack from home. I've tried charging, transportation and then re-peak an hour later. Compared to this, I get better results with charging and after 2 hours do the boost thing. But nothing beat a full charge just before race
I'm not sure how this affect pack lifetime, so I only do it on my older packs.
Old 04-16-2004, 12:46 PM   #154
etzkev's Avatar
Send a message via AIM to etzkev
Thats good that the boosting actually works well, but do you think it might damage some packs?
-etzkev
etzkev is offline   Reply With Quote
Old 04-16-2004, 12:50 PM   #155
-etzkev
dont know, time will show.... It's partial discharging and charging...
Old 04-16-2004, 12:52 PM   #156
etzkev's Avatar
Yeah, which is similar to a "Pulse" charge, which isn't good for NIMH batteries.
Old 04-17-2004, 06:14 AM   #157
sosidge's Avatar
Babylou - the "Battery Info" settings are automatically set once you've gone through them all - no need to "save" them.
Maybe I'll draw up a more straightforward manual...
Etzkev - the CDC's "Boost" charge is not a "pulse charge". It just discharges for a short-time before going to a linear peak charge. No reason why it would damage batteries - just don't use it on a warm pack - you'll risk overheating it.
Old 04-17-2004, 07:13 AM   #158
etzkev's Avatar
Oh, I thought Cole was saying that it repeatedly discharges then charges. But yeah, that isn't a pulse charge and I couldn't see how it would hurt the batts.
-etzkev
Old 04-22-2004, 02:30 AM   #159
Send a message via ICQ to rcnewb2004
When do you need to cycle a battery? Is there any reason besides from it having a memory effect?
rcnewb2004 is offline   Reply With Quote
Old 04-22-2004, 02:37 AM   #160
PSI Racing's Avatar
What's the difference between RC3300HV and GP3300 batteries?
Which one is better?
PSI Racing is offline   Reply With Quote
Old 04-22-2004, 02:41 AM   #161
Brands...
From what I've been told, GP are both better and cheaper. I'm running GP and are very satisfied. Havent tried Sanyo....
Old 04-22-2004, 02:45 AM   #162
If you take proper care of your cells and you use then regularly, you dont really need cycling.
Cycling can "wake up" older cells or cells that have been stored for a long, long time... But it's the same as do a full charge and then race them... Except you dont have to be bored with tired cells on the track...
One reason could be to check numbers on the discharger.
Just remember, that packs have a certain lifetime. So for each cycle, you have one less on the track.
Old 04-22-2004, 06:04 AM   #163
THe charger just takes time to learn.. So far so good with everything... Thanks for the tips.....
Old 04-22-2004, 06:55 AM   #164
So you just got this charger? What do you think of it? I find it's THE charger with best value for money.
Old 04-22-2004, 07:25 AM   #165
So far it is pretty nice. I have only charged a few batteries with it. I had a 2400 Nicd battery that would not charge on my Intellipeak charge.. It would maybe run for a min.. And this battery was practically brand new... I cycled it once on this charger and it ran for about 6 min just messing out in the street... last night I charged up some NiMH batteries I just bought.. I used the partial charge just to charge them up 50% for storing.. Not sure when I will use them next.. But it has alittle readying telling you how much it charge the batter up to.. the display is 1650mah.. which is 50% of the battery capacity...
It is a bit confusing at first.. still trying different things with it.. For the $160 it is pretty good... I think the options are much better then the LRP competition.. But that model as well has other features I wish that was on this Integy model such as running a lathe... Now I have to look at maybe getting the Indi dyno (ANother $100) to run the lathe.. but also tests the motor as well... Lathe is on order.. bought the Integy Super lathe(??) .. I have borrowed the indi dyno from a fellow racer to test...
So far, looks to be like a good setup and by the time next season starts I hope to be a pro.... :-)
Integy INDI 16x5v6/Eagle CDC ver6.0B silverM3 R/C Items: For Sale/Trade 1 07-29-2006 07:36 PM
Indi 16x5v6 Charger Pro Parts R/C Items: For Sale/Trade 8 02-19-2005 07:29 PM
***TWO Integy/Eagle/CDC 16x5v6 Chargers*** =MisFitz= NuKe R/C Items: For Sale/Trade 4 02-13-2005 08:45 PM
Eagle CDC V6.0B/Integy 16x5v6 sosidge Electric On-Road 7 10-18-2003 04:25 PM
Indi 16x5v6 AC/DC lilshortyc3 Electric On-Road 110 02-13-2003 07:35 AM
