Old 01-18-2010, 06:41 PM   #1
Default Will 30 tires have enough grip for carpet?
Wondering if 30 tires are good enough for carpet or should I get 26 or 24's?
Ginsu is offline   Reply With Quote
Old 01-18-2010, 06:58 PM   #2
stiltskin's Avatar
Trader Rating: 102 (100%+)
It depends on your track conditions. Jaco blues are a 32 rating and seem to be a popular spec tire. Locally, Sorex 24s and CS22s perform better. Just have to see what the fast guys at your track are running.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-18-2010, 07:01 PM   #3
cwoods34's Avatar
Two Sundays ago I ran 32's on my 13.5 car, and they hooked up great. I had used 28's the first 2 rounds, then went to 32's for round 3 and the mains. The traction had come up just enough that the 32's felt as planted as the 28's did in the morning.
I had started out with 24's when I built the car, but I noticed that towards the end of the day the car was hard to drive. It wasn't traction rolling, but it felt like I was fighting the car because of the tires. I threw on the 28's I mentioned and it helped a lot, and the 32's even more so.
Hope this info helps!
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 01-18-2010, 07:21 PM   #4
Thanks to both of you that helped.
Old 01-19-2010, 01:07 AM   #5
WheelNut's Avatar
Send a message via MSN to WheelNut
If the track has a lot of groove they will be really good. If it is fresh carpet or a new track layout and there is no racing line yet you will probably be better off running something softer. The insert used in the tire and the wheel will have an effect as well. Basically you just don't want to have the tires so soft that they start to overheat 1/2 of the way into a run.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 01-19-2010, 07:18 AM   #6
so if running the 30's on carpet with decent traction will I want a soft, medium or hard insert?
Old 01-19-2010, 07:22 AM   #7
wondering same thing.
microcrazy24 is offline   Reply With Quote
Old 01-19-2010, 11:39 AM   #8
Skiddins's Avatar
Have used Pre-built Sorex 32's on carpet before now with good results.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-19-2010, 01:36 PM   #9
cwoods34's Avatar
That's exactly what I was using Skiddins, straight-outta-the-bag Sorex 32's. Great tires!
Duratrax Vendetta TC duneland Micro and Mini Scales 604 01-09-2011 08:59 PM
Slapmaster Tools MS2.3 Slapmaster6000 Electric On-Road 128 10-03-2006 11:42 PM
Barracuda from Alex racing rcruv Electric On-Road 5110 02-27-2004 03:01 PM
