Power supply question? >
Old 03-19-2004, 01:59 PM
Default Power supply question?
How can tell if a power supply can handle two chargers? How many amps does it have to handle or how do you figure out how many amps two chargers will make or whatever??
Thanks!
stumper is offline
Old 03-19-2004, 02:01 PM
Generally you want it to put out a few more amps than you will draw off it. For example if you want to run 2 chargers and you charge at 5.5 amp each then they will pull 11 amp. Get a PS that will put out like 15 amp and you should have no problem. I personally went ahead and got a 25 amp PS so I knew I would not have any problems with 2 chargers.
bbentley40 is offline
Old 03-19-2004, 02:19 PM
Thanks!
stumper is offline
Old 03-19-2004, 02:20 PM
John Fontaine's Avatar
i have a rivergate 30 amp, it runs two chargers, my rayspeed discharger and tire truer with no problem.
But yeah, add up the amerage you're going to use via charging and add 2-5.
John
John Fontaine is offline
Old 03-19-2004, 03:54 PM
PitCrew's Avatar
I run two chargers at 6 amps each off of one of the Ebay Cosel 13amp power supplys. Been doing so for almost 6 months without a single problem.
PitCrew is offline
