Old 01-17-2010, 11:16 AM   #1
Trader Rating: 20 (100%+)
Default rear diff question
When building a rear diff should it feel "grindy" when done. I tightened it all the way and then loosened 1/8 of a turn like the manual said and it feels rough. Do I loosen it more until it is smooth? Add more diff lube? Thanks in advance.
storytyme is offline   Reply With Quote
Old 01-17-2010, 12:00 PM   #2
LOW ET's Avatar
Trader Rating: 97 (100%+)
rear diff on what?
it should feel very smooth, most likely it's to tight. no need to add extra grease, it just gets slung off the diff when things get spinning.
LOW ET is offline   Reply With Quote
Old 01-17-2010, 12:15 PM   #3
Originally Posted by LOW ET View Post
rear diff on what?
It is on a TC5. Thanks for the info. I will add some grease and loosen it.
Old 01-17-2010, 12:39 PM   #4
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
if it feels gritty after a rebuild the diff balls are flattened and need replaced
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-17-2010, 12:51 PM   #5
If I loosen it more than 1/8 it feels smoother. Should I do that instead. The car is fairly new, so I don't think the diff balls are flat, thoughts?????
Old 01-17-2010, 12:53 PM   #6
20 SMOKE's Avatar
if it was overtightened it will flatten them,try loosening and go from there but you may need new one's down the road
Jamie W
Old 01-17-2010, 12:56 PM   #7
LOW ET's Avatar
my post said NOT to add more grease.
Old 01-17-2010, 02:15 PM   #8
Rozzer's Avatar
You should loosen your diff to the edge of no slip or very little slip under pressure.
Rozzer is offline   Reply With Quote
Old 01-17-2010, 03:16 PM   #9
It said to tighten until spring is compressed so I figured that was when it couldn't go any more by hand tightening it. I will loosen it a little more and not add grease. Also, how do you know if it slips? Is this only possible after driving it?
Old 01-17-2010, 03:20 PM   #10
Redwood's Avatar
The diff rings are probably a little worn, it happens with use.
You should tighten your diffs a little at a time until you can no longer slip the diff with your hand.
Then either run it, or run it in on at the table by holding one wheel and using a little throttle. Then retighten it until it doesn't slip.
Or watch how the European champion does it here:
http://www.youtube.com/watch?v=YOMu6...layer_embedded
Regards
Neal
Redwood is offline   Reply With Quote
Old 01-17-2010, 06:02 PM   #11
Regards
Neal
If I grab the rear wheels and turn them in opposite directions should they move easily or with some resistance?
Old 01-17-2010, 06:09 PM   #12
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
A tiny bit of resistance... but it should feel pretty free and very smooth. Its the kind of thing you need to be shown in person.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-17-2010, 06:13 PM   #13
trerc's Avatar
Trader Rating: 89 (100%+)
+1 Work you diff as you tighten it and NEVER tighten it all the way, the manual settings are almost always too tight.
Chuck a small allen key across the top plate in one of the holes on your spur to hold the spur then grab both tires at the same time and spin in the same direction, it should be just tight to the point it doesn't easily slip, free is fast. Here's a vid to help you out.
+ YouTube Video
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 01-17-2010, 06:28 PM   #14
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
A very good video! Watch and learn+++
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
TC3 Diff Question MadMikeB Electric On-Road 18 04-03-2005 08:13 PM
1/12 Diff Question Takt Electric On-Road 23 12-09-2004 02:26 PM
