Old 01-17-2010, 08:19 AM   #1
Default Spur gear on Xray T3 EU
What is the biggest Spur gear who fits on the Xray T3EU??
Im now sitting and ordering Spur and pinion gear, so I have to be sure it will fits. I have choose 114 P64 & 116 P64, do they fits on my T3, or will they be to big ????
dartvidar is offline   Reply With Quote
Old 01-17-2010, 08:25 AM   #2
Trader Rating: 33 (100%+)
What motor and what size of track are you going to be running on? I don't think you will need spurs that large if you are running brush-less. A 106 is the largest I have ran. As for pinions, that depends on motor, track size, and speed control. For the non timed advance speed controls like GTB you will need much larger pinions than say a Tekin Rs.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 01-17-2010, 08:34 AM   #3
I will use LRP V12 4.5T and LRP SXX TC spec, I will run little bit indoor and out door. In accordance to LRP I will need a FDR around 9.5 - 8.5
I did then calculate out of the charts, I can use 23/116 & 26/116 That will be 9.5 & 8.5. I have heard some one say it's good to use larger spur??
So what spur size it's recomended for modify and stock, I will use 4.5T on modify and 10.5T on stock???
Old 01-17-2010, 10:07 AM   #4
RC MARKET's Avatar
114T or 116T
RC MARKET is offline   Reply With Quote
Old 01-18-2010, 07:07 AM   #5
The larger spur will allow to adjust ratio at a finer rate, and it moves the motor a little more forward which takes a little weight off the rear axles, so in theory would give a bit more steering. For those ratios I'd recommend the 116.
Chris Lockhart
Radio Operated Cars of Kelowna (R.O.C.K Racing) Dan Boundy Canadian R/C Scene 5438 09-29-2014 10:04 PM
