New Tc3 Chassis
Old 03-24-2004, 11:30 AM
  #61
TeamPRP's Avatar
Originally posted by ixlr8nz
So have you guys seen how my car has the batteries down the centre?
Yeah, good idea. I've always been a fan of centered weight. Which is why I got the Pro 3. Unfortunately the car had too many other problems, and not just the flex(we fixed that). . . If done correctly it would make for a very nice car.
I'd suggest you post your car in a new thread on this forum, you don't want to hijack someone elses thread do you?
TeamPRP is offline
Old 03-24-2004, 03:03 PM
  #62
tcguy808's Avatar
what is the issue here...going fast or changing battery setup...if you dont wanna change your battery config...then your chassis will limit you...i have a few friends that have done a similar battery mod...called the 4x2 chassis for short...and they say it drives like a totally different car...and sometimes going fast means that you have to do things that you would rather not do or are not used to doing...
my $.02
tcguy808 is offline
Old 03-24-2004, 03:49 PM
  #63
Chris08527's Avatar
Trader Rating: 16 (100%+)
hey guys been reading all you stuff and like the new ideas with battery placement
i live in jersey so most people with aftermarket chasis use the IRS being it is located in jersey
i think the main thing with any car is SET-UP and making the little adjustments and ones driving ability
if i have the BRAND NEW HOT CHASIS and i cant set it up it is useless to me
if you cant set it up and you crash a couple of times a race it doesnt matter what you drive they all go the same speed on the roof . . .
lets practice driving a little more and not worry so much about all the chasis hype . . .
Chris08527
JRC
Chris08527 is offline
Old 03-25-2004, 05:45 PM
  #64
tcguy808's Avatar
very valid point...finish before you win....
tcguy808 is offline
Old 03-28-2004, 06:04 AM
  #65
BobW's Avatar
I met with the CNC shop in TO saturday and came to an agreement for the fabrication of 6 chassis. 3 weeks to hardware in my hands. As soon as I have them I will post some pics on the website.
BobW is offline
Old 03-28-2004, 12:06 PM
  #66
EDWARD2003's Avatar
Default Cant wait to see it!
I cant wait to mount the chassis to my TC3.. Its going to look killer!
Pickering
EDWARD2003 is offline
Old 04-07-2004, 09:55 PM
  #67
nashrcracer's Avatar
heck I did it like that to my YR4-M2 back 5 years ago it's not a new idea. I just copied from penguin rc
http://www.penguinrc.com/products/yokomo/yr4/1700.shtml
nashrcracer is offline
Old 04-08-2004, 03:00 AM
  #68
Crashmaster's Avatar
Has anyone tried a moded chassis for the TC3 with a 3 x 3 layout (3 one side, 3 infront of the motor), and if so what was it like??? Just wondering as I would have fought (although I know absolutaley nothing about these things ) that this would be better balanced than a 4 x 2 layout??
Cheers
Crashmaster
Crashmaster is offline
Old 04-08-2004, 05:24 PM
  #69
BobW's Avatar
Default Fabrication underway
Fabrication is underway. I should have the first prototype next week.
Here is my test plan. I will run 3 simulated 5 min. races with transponders on our Kingston track using my current TC3 setup ( chassis modified to lower batteries and move inboard). I will then swap the chassis reset the weight balance and repeat the process using the the same batteries and motor. I do not plan to change shock oil, springs or suspension geometry for this initial comparison. After it is all done I will compare and post the results.
I want to do a fair comparison and this is the best way I can think of doing it. Any other suggestions.? If you want to check out my local track go to:
http://leadingedgehobbies.com
and follow the links to Leading Edge RC Speedway and/or Race Results.
Bob
BobW is offline
Old 04-08-2004, 08:27 PM
  #70
ixlr8nz: Letme guess. You put some spacers under the transmission cases and bolted it on to your chassis? Either that or you re-engineered the tranny cases
I came up with that idea too a few weeks ago at school during study hall. Can you send me a few pics of the top....I want to help a bit in the enginering of your project and I'd love to be a test driver. Drop me a line at [email protected] but if you send any pics/attachments send them to [email protected]
I think I can seriously help you out. I had the same idea.....
The Black Kat is offline
Old 04-08-2004, 09:58 PM
  #71
Sorry I can't give you any more pics or details as the car is under wraps for now. I have actually been racing it for a bit already, but it was found to be illegal at the New Zealand champs (kind of vague rulings) where I was actually running 5th in qualifying and had a lot of pressure on me from the officals which meant I was struggling to concentrate as you would expect, so I have had to run a std tc3 for now at local races.
I have actually put my name down for the worlds and a couple of other overseas races where I will be running an updated version which should be a bit better.
cya
Mike
ixlr8nz is offline
Old 04-08-2004, 10:14 PM
  #72
I'll send you another IM with a few ideas I have that might be able to help you. I have no cash and no hopes of producing a car so I figure I can help you a bit...
Old 04-17-2004, 11:49 PM
  #73
EDWARD2003's Avatar
Default O BABY
Drooool
www.members.kingston.net/rwdesign
