Old 01-15-2010, 04:03 AM   #1
Nuno Gancho's Avatar
Default Weight distribution
How should i distribute the weight in my car to achive the minimum weight but having some more traction or grip in front/rear in aceleration/braking enter/exit corner of the car.
Thansk for the help.
Best Regards.
Nuno Gancho is offline   Reply With Quote
Old 01-15-2010, 05:08 AM   #2
trerc's Avatar
Trader Rating: 89 (100%+)
The car should be balanced on all four corners. From there you can work with your set up to achieve more grip where needed.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 01-15-2010, 05:23 AM   #3
Yes, but adding more wheight in front or rear how would the grip work, in aceleration/brake in or out corner..
Old 01-15-2010, 06:02 AM   #4
trerc's Avatar
Usually adding more weight in the rear will give you more traction, adding weight on the front will add more steering but it turn can take traction from the rear...
Old 01-15-2010, 07:13 AM   #5
Toh WL's Avatar
Use the Hudy Tweak Station.... it gives the most accurate results to my experience. This will eventually solve your problems.
Toh WL is offline   Reply With Quote
Old 01-15-2010, 09:26 AM   #6
05forfun's Avatar
Trader Rating: 81 (100%+)
The total weight will be the same regardless how you distribute it to the car, if you are talking about achieving minimum weight, distribute the weight to different places will make no difference. The traction is proportional to the normal load applying to the tires, i.e. adding more weight will, in theory, give you more traction, but it will hurt the acceleration, generate more weight transfer, etc. So lets assume your car has been tuned to be optimal mechanically (camber, caster, toe, weight distribution...), the only way you can gain more traction with minimum weight is to use aerodynamic down force, which means you need a good body shell.
05forfun is offline   Reply With Quote
Old 01-15-2010, 10:13 AM   #7
Toh WL's Avatar
You can opt for Protoform Mazda Speed 6 190mm as one good example bodyshell commonly used.
Old 01-15-2010, 10:24 AM   #8
Ok, if i have wheight to put in the car, were should i put, and what will it do.
Old 01-15-2010, 11:09 AM   #9
Trader Rating: 38 (100%+)
This is how I do the weights in my car. I first balance the car with as little weight as possible (usually means adding some weight to the battery side of the car towards the outside edges). I try to do equal amounts in front of and behind the battery. Then I weigh the car. The difference between your min weight and what you weigh I then add down the center line of the chassis near the middle.
or8ital is offline   Reply With Quote
Old 01-15-2010, 01:17 PM   #10
CraigM's Avatar
Trader Rating: 34 (100%+)
Without wanting to start an argument, these statements are not correct. Weight placed at the front will reduce rotation and may create understeer, weight placed at the back will increases rotation and may cause oversteer.
The best way I've seen to measure weight distribution without having to worry about tweak is to attach a pair of droop blocks across each axle with double sided tape and then weigh the car with each droop block sitting on a separate scale. Turn the car around to cancel out any inconsistencies between the scales and take the average weight for both front and rear and you have your base weight distribution. From there you can move weight forward or back to encourage more or less rotation
CraigM is offline   Reply With Quote
Old 01-15-2010, 01:35 PM   #11
gashuffer's Avatar
Trader Rating: 48 (100%+)
That's a three point calculation. I would put a balance block at the end that's not on a scale.
T-Sal
gashuffer is offline   Reply With Quote
Old 01-15-2010, 03:05 PM   #12
sosidge's Avatar
You have to distinguish between the inertia caused by the weight distribution and the tyre loadings caused by it.
If you are working within the tyre's limits, more weight over one axle will make that axle less responsive to inputs, while also having more grip.
However, when you reach the limits of the tyres, the heavier end of the car will lose traction first, and inertia will then make it harder to bring back into line.
As with all aspects of car setup, it is a balance. 50/50 balance left/right is a target that every non-oval car should aim for, front/rear balance is a matter of choice. Most 4wd touring cars are close to 50/50 front/rear, with a small bias towards the rear if anything.
Weight Distribution - How to do perfectly? Aku-Man Electric On-Road 142 10-19-2010 10:56 PM
Weight distribution on touring sedan OscarF1 Electric On-Road 11 05-01-2007 02:02 PM
Losi xxx-cr,novak gt7,comm lathe,tire warmers,integy weight distribution,CS27 tires crusty Australia For Sale/Trade 11 02-15-2007 02:42 AM
Integy Team Digital Weight Distribution System BigJim14226 R/C Items: For Sale/Trade 10 06-15-2005 08:14 AM
Integy Weight distribution tool info wanted PizzaDude Electric On-Road 17 07-30-2003 12:10 AM
