Schumacher Corner
Hi Chris,
We have 2.5mm chassis and top deck (U3146 and U3246) and option carpet style shock towers (U2714 and u2715) all available as option parts.
Thanks for the quick reply Shawn.
Is that going to add alot on top of the kit price?
Is there any knowledge on what chassis combination is required for rubber tires on carpet too?
Cheers, Chris.
Cheers, Chris.
Who's driving Schumacher for the FSEARA 2008-09 season???
Super Moderator
and me
Hunsinger and Hunsinger Jr just picked up new Mi3.5s yesterday too :-)
Any set up suggestions for that track? What's the grip level there, and what shock oil/sprig combo is good for the track?
Planning to come up on Sunday and trying to get any tips before hand
The "PW FSEARA" setup from the schuie site is still the best starting point on your set up. Shocks 30-35wt w/schuie white springs, I may try AE green springs to get some grip with the jacos, hopefully Shawn and Adam can bring a good IceTruckers setup for those tires!
R/C Tech Elite Member
Rumor has it if you rub Wendy's french fries grease on the tires thats your best bet for some solid grip
Thanks Troy...thanks for the spring tip. AE green springs or Serpent white(13lbs) should be a bit softer than the 14lb Schiu whites(allegedly-'cause they feel like 16lbs). I guess this track is med grip track, tops...
any news on the release date for the CAT
