Schumacher Corner
well now i'm confused, what does the chassis have to do with servo saver height?
hey guys does any one have a good baseline set up for low grip bumpy aphsalt?
Regional Moderator
yeh gotta update that its (finally)a mi3
I am considering getting a MI3 for asphalt rubber racing this season. I also do carpet rubber racing. What changes need to be made back and forth to get the car setup from asphalt to carpet and vice versa?
I currently run a TC5 with lipos and a 13.5 BL.
Chirag
Chirag
Looks like McGoo landed himself BQ with the Mi3 at Carpet Nationals in Omaha; .3 outta the A! Not to mention Steve "Magic" Marker near the top of the B as well in 13.5 rubber. If I am not mistaken both were running the SP GT!
Team Schui in effect!
Aaron, go to gearchart.com and choose the 1.8 option for Schumacher. You will need a 70t spur and a 36t pinion to get teh required 3.5 fdr or 56mm rollout. The 70t (48 pitch) is a schumacher part and the pinions - I use RW - are readily available in the zone of 35 through 38.
Thanks Heavy
I have a modified set-up for a low grip bumpy track, but its with 6cells,
I'm still testing a 5cell set-up and i'm not confident on writing it down on paper yet.
Set-up 6cell Mod bumpy track low grip
Hey Josh,
hi guys
I 'm just wondering how important is the side to side chassis balance cos im running lipo with no added weight ....
also just bought an 5 cell chassis gonna use with lipo does it makes any negative effect over 6 cell chassis (current 6 cell chassis really in bad cond. thats why i've got near new 5 cell chassis on flebay )
cheers
cheers
Try this setup. I think it will be a good starting point.
You might want to add some more rear toe.
hi guys
cheers
cheers
Juan aveytia was also running sp stuff in the 13.5 a main.
Thanx Andrew
