Schumacher Corner
which ESC do you think is better??
1st=0.050ohm, 75A,Drive frequency: 2500 Hz
2nd=0.0055ohm, 40A, Drive frequency: 1000 Hz ,Brake frequency: 1000 Hz
Thanx for advices
Thanx for advices
imo which is basic prob the first higher rating and smoother throttle due to the higher frequency.
where is adrian when u need him?
Had a blast at the IIC! Didnt do as well as I would have liked, but not a blowout considering this was my 1st time on carpet with rubber tire. I put Allen Hewitts set-up on it and only made a few changes to make the car more aggressive. My car was really good, I was just over-driving it.
As usual, support from Schumacher USA was outstanding! The team worked very well together and we all made sure that everyones Mi3 was dialed. We all knew the car would be great in rubber, but Goetz and McGoo's cars we insane on foam tires! Mcgoo's car was dialed!
Big Congrats to Goetz, Caster, Hewitt, Maddison, and all the other guys running schuie's. Great hanging out with you guys and picking your brains. I'll be at the gate for the ruber class at the classic
well done Team schumacher that was the first major carpet competition of the mi3 and results are brilliant...New carpet setup sheets will helps tens of mi3 drivers over the globe...
Regional Moderator
I'm sure once they get settled in from the race they will. I know McGoo will be posting his setup via PDF on this site and the Schumacher USA site as well.
Regional Moderator
This was the easiest and best car i have ever driven in my life. I felt 100% confident that I could place this car anywhere I wanted to. I feel like the Mi3 turned a few heads as well b/c of how good Goetz and my car was looking....
My third qualifier I was down to 11.1's, 11.2's and a string of 11.3's. It is so bitter sweet - I was only 5 seconds out of the A, 1.5 seconds out of the B and that put me 23rd qualifier....you gotta love national level stock racing!!!!
Dawgmeat - i would have agreed with that statement 2 weeks ago, but I only made 3 changes from my home track which is low-med bite. I went one softer spring rate in the back, took the arm sweep out in front, and took .5 toe out of the rear. Other than that - I was running exactly what I was running back home.
I feel confident that this setup is pretty going to be a great base point for anyone running foams. I gotta give props to where props are due - my buddies Steve 'Magic' Marker & Andrew Doherty, as well as Goetz helping me iron this setup out.....
As for the PDF - it isn't allowing me to change my rear ride height and droop - they copy and paste each other.....so i am running 4.0mm ride height with 6.5mm uptravel
McGoo is my hero, after Brian of course.
Regional Moderator
Thanks for throwing that up for us McGoo
