Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 07-29-2007, 12:50 PM
  #20971
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
thanks dude!
Support . . .# 1 reason I love Schumacher!
andrewdoherty is offline
Old 07-29-2007, 12:58 PM
  #20972
AdrianM's Avatar
Nick Case's Modified Schumacher Fusion 21 with a brushless motor and lipo battery won this years Fastest R/C car contest with a 127mph run!
AdrianM is offline
Old 07-30-2007, 01:11 PM
  #20973
chris72983's Avatar
Jon Kerr, Just wanted to say thanks for the excellent setup from reedy. Only ended up changing two things after running it, went with a little bit harder tire for stock class and ran the next step up harder spring on the front. After that it was dead on. Thanks Again
chris72983 is offline
Old 07-30-2007, 01:35 PM
  #20974
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Anytime. Glad to hear it's working out well.
Jon Kerr is offline
Old 07-30-2007, 05:10 PM
  #20975
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Kerr definately had a dialed car at the RROC..
Randy Caster is offline
Old 07-30-2007, 08:31 PM
  #20976
Regional Moderator
Darkseid's Avatar
Just as a re-cap to what I think I've been seeing around here. To get ready for carpet season, this is the good stuff to pick up.
-2.5mm chassis
-front diff
-6 deg C-hubs
Already got the heavy springs and stuff covered, just wondering about the specific Mi3 stuff.
Darkseid is offline
Old 07-30-2007, 11:19 PM
  #20977
Trader Rating: 19 (100%+)
I tries some stuff this last weekend on a really high bite asphault track car was dialed i ran the
-2.5 carpet top deck (new one)
-gold sway bar
-light front blue spring but with rear white
-silver rear sway
-and 1 mm kick up-
-and the aluminum 1 degree rear hubs
the gold sway and kick up helped in the hight spead
and the hubs helpd to let the car rotate through the corner to help steering
teammidget lilB is offline
Old 07-30-2007, 11:34 PM
  #20978
Trader Rating: 90 (100%+)
-2.5mm chassis
-front diff
-6 deg C-hubs
Darkseid,
I think the stiff/wide/carpet top deck is needed more than the thicker chassis. Tracks these days are not producing the amount of grip we experienced a few years ago (except for CEFX Raceway).
Goetz can probably give better advice as he is the carpet specialist for this car, but save yourself a couple of bucks and try the stiff top deck first.
RBLove is offline
Old 07-31-2007, 06:36 AM
  #20979
Jon Kerr's Avatar
Wish the driver had been as dialed as the car. We would have had 2 Mi3's in the show in 19 turn.
Jon Kerr is offline
Old 07-31-2007, 08:22 AM
  #20980
-2.5mm chassis
-front diff
-6 deg C-hubs
From the set ups I have sen and the week or two I have had on foams with the Mi3 I am not sure you would need the 6* hubs yet. Ive been running 4* with Goetz's set up from the book (for te most part) and the car is on rails on our low grip carpet. We duplicated the vegas layout at our track and after running it alst night I am VERY pleased.
Old 07-31-2007, 08:36 AM
  #20981
has anyone run the new jaco rubber tyre yet?
thanks jimmy
jimmy..maddison is offline
Old 07-31-2007, 08:57 AM
  #20982
redlion's Avatar
thanks jimmy
Hey Jimmy,
I have run the tire on my mi3 at the C. I ran the "blues" they seemed to be just like the "cs32 take off" just a little more sticky.
Just my 2 cent
Wes
redlion is offline
Old 07-31-2007, 09:01 AM
  #20983
so greens will be a tad softer do you have a picture of the profile?
thanks jimmy
Old 07-31-2007, 09:04 AM
  #20984
redlion's Avatar
thanks jimmy
They apper to be the same profile, just check the glue every run. The rims seem to be harder. I do not know if they have fixed the glue problem?
Wes
redlion is offline
Old 07-31-2007, 09:07 AM
  #20985
where is the best place to get some from that will ship to the uk so i can start testing?
jimmy
