Schumacher Corner
thanks andrew!
looks like i'm going with a one-way or bally,
there is NO traction where i'm running.
cheers again for the advice.
sure thing bro.
More Kerr bait . . .
Can *anyone* suggest what difference I might feel if any betwen widening the rear of my Mi3 at the hexes versus widening it at the bulkhead?
Some Lipo install pics. Pictures worth a thousand words. Ive had plenty of collisions with thsi setup and had no signs of any problems. I ran my corally like this for almost a year too with no failures.
I used a couple 3mm shims under the lower center track rod mounting bracket to raise the track rod to clear the LiPo.
CVD Chatter
O.K. Here goes. Has anyone else notice the amount of CVD chatter the MI3 has when you have the wheels off the ground turn full lock and apply a SMALL amount of throttle (I have glued the 2mm shims to the front hubs and correctly set my EPA)? I was wondering if anyone has a fix for this as it seems to develop a lot of vibration through the front end. I'm not 100% sure but I think it was doing the same thing on the track as well. This may also be accelerating the destruction of front drive shaft components. What I was wondering was has anyone tried any of the new track rod sets as I believe the problem maybe developing from excessive Ackerman effect creating a large slip angle on the inside wheel, making the CVD transmit through a larger angle and causing the vibration.
Other peoples thoughts, experiences?????
Andrew
Andrew
Widening at the bulk head will also affect your shock angle and lay your shocks down a little bit and you will also have to adjust your camber which will be longer. Where as at the wheel your only affecting at that point.
Andrew
Andrew
Andrew
Andrew
Hi, yes i had quite a lot of chatter when i had the car off the ground it like shook the whole car, however i didnt think into it too much and now have used ther car half a dozen times. Now i have hardly any chatter now, maybe it takes time for everything to settle in, however it did seemed to improve when i recieved my new drivehshafts, the ones with the updated pins.
Ok hope this helps
Steve
Thanks Steve, I think my kit has the updated shafts. They came with the flat spot on the CVD pin (Looked like it was done by hand?) I will give it a few more runs and see if it improves. Has anyone tried a different brand of CVD in their car?
Andrew
Andrew
I have seen this question posted on almosted every car thread. and the reason is that we all used the same thing. it really is a universal joint and not a true "CVD'. Now I do not have a losi, but they build a true "CVD" and I would think that they would not have this problem. if you want more on this, check out http://rctech.net/forum/showthread.php?t=91463
Nice! Good question though. I've never really tried it. Taking out the wheel shim and widening the inner hinge pin location would change your shock angel, camber link length, and your outer hinge pin location in the wheel. All of these will change the handling of the car. Maybe something to play with at the track sometime.
one thing it does is that the wheel will now rub on the arms. at least in the rear. I uhm "lost" the shim that the kits come with. so i ran mine without them. now the arms in the rear rub on the wheel
Widening it at the bulkhead will move the pivot point farther out, making the rear end roll less, which will generally take away a little rear traction.
thatnks for all the helpfull insight guys.
Yang-were you running your bulkheads wide, and using the 1 mm spacers? I have 1mm spacers you can have. Remind me on Sat.
i actually shimmed at the bulkhead and then ran a thin spacer. but I have room to add another space. I need to measure out the spacers I have. they are a team tamale custom jobby. he cut hex spacers for me.
Trader Rating: 102 (100%+)
Yang...
ya need to convince Larry to make some schui stuff...
Chubs...and bling steering knuckles...
hurry..hurry....
hurry..hurry....
