Schumacher Corner
It's a sony "a100". It's more to do with the lighting than the camera.
http://www.sonystyle.com/webapp/wcs/...play?jspStoreDhttp://www.sonystyle.com/webapp/wcs/...dkey=ClickInfo
sorry about the length of that link.
Super Moderator
Country - The bearings are not ABEC rated. They are however, built to Schumacher specs and are really darned nice.
Here is a bit of bearing info that applies to this question...
High ABEC rated bearings have tight tolerances. The better the rating the tighter the tolerances and the better the internal surface finishes are. This is good and bad. When new can clean expensive ABEC bearings are great. Unfortunatly after a few runs they can get dirty and the tight tolerances work against you. It is much more important to keep a high grade bearing clean in order for it to be free.
Starting with the Mi2EC Schumacher has been buying bearings built to thier specs. They have slightly looser tolerances but very fine surface finishes on the bearing races and very good quality balls. They also come oiled, not greased, so they are free and fast right out of the box.
The kit bearings are so good most of the factory team drivers use the stock bearings.
If you want the best possible bearings for you Mi3 the Schumacher Ceramic bearing set uses the same inner and outer races at the kit bearings but use silicon nitride ceramic balls for ultimate smoothness and durability.
Thanks Adrian.
Are any of you Floridians going to MinReg? I'll like to the Mi3 in action.
Super Moderator
CountryHick-
That wiring job is nice! Makes me want to rush wiring my Brushless MI3
yoyoyo Randy, look forward to catching up with you at vegas!!
hows things with the car , what did you use to dye you white plastic parts??
thanks jimmy
thanks jimmy
I was thinking the same thing. I would love to wire my car like that! It looks pretty sweet!
Wire cover
I"m sure you can find this stuff in the States somwhere, but because I live in Australia I got mine here.
http://www.techflex.biz/index.html
