-   -   Schumacher Corner (https://www.rctech.net/forum/electric-road/36-schumacher-corner.html)
Racer X 08-26-2001 09:58 PM
Currently, I'm only running about 2mm droop with my setup.
Corey Bernardo 08-27-2001 09:29 AM
cool thanks RacerX! I was running about 3mm f/r, but the car felt weird so I backed it off to 2mm and its great again.....
My problem was turning to the right it was coming around but to the left it was planted! I totally fixed the problem on those new IRS 4 digital scales for each tire. I highly reccomend using that instead of a tweak board! Only thing is its about 300 bucks! lol
PaulP 08-27-2001 11:15 AM
Hi Guys
well after a break from R/C racing for a while I am back. What has been new with the schuie's I hope my Axis 2 will still kick butt.
What can people tell me about this new CS speedo? I am in need of a new one and was thinking about getting an LRP7.1
any new tricks with set-up that one should be aware of? a lot of information prob got lost when RCTouring went down.
PS has the schuie webpage changed?
Well talk to you all soon
paul
Racer X 08-27-2001 11:37 AM
Paul: Your A2 should still kick butt. I can't tell you anything about the CS stuff other than it can be hard to get at times. Most people are using either the LRP Quantum or 7.1, , Novak TC, or the Keyence Zero Extreme ESCs right now. In the next post I'll put my current setup...
Racer X 08-27-2001 11:51 AM
My current setup:
Asphalt board track, high bite and smooth
Ft and rear: 70wt, 2hole, red spring, center hole on shock tower, inner hole on arm, in line hub, 1.5 camber, lower bulkhead mounts.
Ft: 10d camber, rear steering holes, C/F chassis (lowered front end), 2mm droop, diff one way
Rear: 2d rear toe, raised C/F rear end, 2mm droop.
PaulP 08-27-2001 12:47 PM
Racer X
Thank you for the help with the set-up that sounds about the same as I had before I took a break. what tires are you using? I have heard that 138G's are still god and that Sorex are good as well, but were mostly for carpet.
I have the one way diff, but have never tried it. What applications would it be for carpet?Pavement? sweeping tracks or tight tracks.
These questions should help you get that post count back up :D
does anyone have the part number for the ABS layshaft? I snapped the spur gear off last time out on carpet.
Paul
Racer X 08-27-2001 01:45 PM
The Sorex 36 with HPI inserts (red for above 85, green for 95, blue for 110) are the best tire out bar none. They don't fall off after the first run and they LAST. The Sorex 28s are for carpet.
One ways give more steering, especially turn in, on high bite tracks and carpet. In either situation, I wouldn't race without one as the car will get through the corner faster than with a conventional diff.
Racer X 08-27-2001 01:46 PM
Try U1912A for the slipper layshaft
Taz_S 08-27-2001 01:49 PM
Rx: what tires do you use at night for SRW.
Racer X 08-27-2001 01:56 PM
Last weekend, I used 36s w/ HPI green inserts during the day, 32s w/ Yok firms (an old set that I've had for about a year and hardly used) after the sun went down. Usually, I just keep running the 36s but it takes like three laps to heat up the tires and five before they are all the way up to temp.
MattW 08-27-2001 02:57 PM
Paulp, that part nuber that Racer X quoted is the slipper clutch with one-way roller. This isn't the abs.
The ABS shaft part number is U2142T - including the collar and pin.
MattW 08-27-2001 03:22 PM
I have 3 CS Rocket MAX's. Can't compare them to 7.1/Quantum but i have been impressed with them and haven't had any problems at all.
Racer X 08-27-2001 03:52 PM
Oops, my bad. I was looking up the part number on a master parts list. It just said 'layshaft - one way'
PaulP 08-27-2001 04:12 PM
RacerX
again thank you with the help. I think I will start out with the one way diff in to see how I like it. Our indoor track size is 72x36 makes it a little tight sometimes especially when they set up a 1/12 scale track.
Matt W
thank you for the part # on the abs layshaft also re the info with the CS max I have been thinking hard about getting one.
Only headache is I live in Canada and getting them could be a headache. Shipping direct from Schumacher sometimes is a worse headache with customs/duty etc:flaming: Yet it would be the same headache if I mailordered anything from the US.
Paul
AdrianM 08-27-2001 07:20 PM
RacerX-Hey, glad to see you on this site.
Powered By: vBulletin v3.9.3.6
