Power Capacitor to gain acceleration
#61
Im still looking for a nice place to put my Capacitor.
I dont want it to be directly on the ESC so i was thinking of putting it on the deans plug on the esc side, where the wires meet the the plug.
what do you all think.
#64
Are these good capacitors for our application? I might want to try one of these on my LRP QC2 in the future, but I only want to try it if there is no risk of damaging my ESC because I havent heard many good things about LRP's customer service. Is there any problem with installing one on a 3 wire ESC becuase the capacitor will have to be connected to one of the motor wires? I doubt it will, but just checking. Will the QC2s reactive software cause any problems with the capacitor?
#65
any capacitor will work as long as it is in the right voltage range. for instance i wouldn't put a capacitor of more than ten volts for a novak gt7. ko speed contollers can handle i think 16 volts. my buddy has twin 4700 microfarad(ten volts-standard cap for gt-7)on his gt-7. mondo punch
#66
Guest
The volts on the caps is the maximum voltage the caps could handle. You could jolly well put a 35V rating caps onto your esc without any problem but is it necessary to use 35V ratings..they cost moreand heavier too. I would use 4700ufd 12V or perhaps 16V ratings max max.
#67
Guest
#68
Are the capactiors that come with the LRP worlds kit good? I know that they are overpriced, but another cap would probably void my warrenty, although I guess if I took it off they'd never know.
#69
Guest
I didn't use the power cap that come with my GM esc. I usually get either 2200uf or 4700uf 16V rating from the local electronic store. They work just find.
You're right ! The LRP power cap kit is way overpriced !
#70
So theres no real chance of the 10,000uf 10v cap hurting my ESC? It sounds like it would benefit it, but I can't be too careful when Ive read that it takes 2+ months to get a LRP ESC back from repair.
#71
Guest
#72
Originally posted by tornado
Nah !
power caps don't hurt it.... water will, no schottky diode or not enough will, motor shorting or jam, over geared ur car but not power caps.
Nah !
#74
Guest
Originally posted by work
is the cap that goes with the GT7 good for racing on stock motors or do i have to replace them? i got mine used but i think its the newer version
#75
HEY MY OLD CAPACITATOR FRIED OFF, WHERE DO YOU INSTALL A 10,000 UF CAPACITATOR CORRECTLY IN THIS SPEED CONTROL. I GOT A FRIEND TO INSTALL IT, PUT I THINK HE INSTALLED IT WRONG... PLEASE SHOW ME WHERE TO CORRECTLY INSTALL IT THANKS..
