Power Capacitor to gain acceleration >
Old 03-21-2004, 06:39 AM
  #16
Tempest2000's Avatar
Trader Rating: 21 (100%+)
thanks tres... a lot of the info in there is correct... the data speaks for itself though
Tempest2000 is offline
Old 03-21-2004, 07:22 AM
  #17
jeffreylin's Avatar
I think the capacitors does one thing--it prevents my transponder from cutting out under full throttle.
jeffreylin is offline
Old 03-21-2004, 02:56 PM
  #18
popsracer's Avatar
Default Power Capacitor to gain acceleration
Guys;
Your arguments remind me of the Global Warming and Ozone Depletion theories.
Each one has Scientists on complete opposite sides of the issue, with mountains of data to support their particular viewpoint.
All I can say is, if you're running (in Stock) without a Big Cap, try one and you WILL notice a difference.
popsracer is offline
Old 03-21-2004, 03:13 PM
  #19
Default Re: Power Capacitor to gain acceleration
Originally posted by popsracer
Guys;
hey, Im Running stock/19turn With Quantum Competition Can you show me a Link With a Cap I can Buy. My Esc does not have the Worlds Upgrade Kit.
True R/C Racing is offline
Old 03-21-2004, 03:16 PM
  #20
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
http://www.hobbyshopper.com/page4.html
Tres is offline
Old 03-21-2004, 03:32 PM
  #21
i thought 4700uf @ 10V is what to run?
Old 03-22-2004, 01:24 AM
  #22
This is $7.
The one in this thread is 2 for $10 for the same one. My friend will be jealous, then I will give him the other one.
I am running a micro with 2/3A's. The other thread said:
"Runing micros I can say for sure that power caps do make a difference, they are especially noticable with batteries that have less output like AAA's that they are with 2/3A's."
This might not be as noticable on subC's.
ratcar is offline
Old 03-22-2004, 01:31 AM
  #23
Brandon R's Avatar
i found some 4700's for 1.25 but they were at 25 volts...does the voltage even matter? well does 10,000 uf 16v do anything good for anybody? $1.50 each...
Brandon R is offline
Old 03-22-2004, 07:15 AM
  #24
Tres's Avatar
any cap won't work...
The capacitors we use have a VERY low ESR value....
There are other ratings for capacitors than just Farad & Voltage value...
What is ESR?
ESR is an abbreviation for Equivalent Series Resistance, the characteristic representing the sum of resistive (ohmic) losses within a capacitor. While ESR is undesirable, all capacitors exhibit it to some degree. Materials and construction techniques used to produce the capacitor all contribute to the component's ESR value. ESR is a frequency dependent characteristic, so comparison between component types should be referenced to same frequency. Industry standard reference for ESR is 100kHz at +25°C. Power dissipation within the capacitor, and the effectiveness of the capacitor's noise suppression characteristics will be related directly to the ESR value
Tres is offline
Old 03-22-2004, 10:15 AM
  #25
popsracer's Avatar
Brandon R;
The HIGHER the voltage rating, the LONGER the Cap will take to charge/discharge (At the voltage we use). There is a very small, but noticable difference when using 10V over 16V Caps.
Ideally a 7.5 volt Cap would be great, but I think the next step down is at 5 volts and electronics like to make LOUD noises when pushed past their voltage/current limits.
Old 03-22-2004, 10:17 AM
  #26
pops would that be good for stock/19turn? with a Lrp quantum?
Old 03-22-2004, 10:49 AM
  #27
Brandon R's Avatar
pop, thanks for the info...learn somethin new every day! But at the speed of electricity what kinda time are we talkin about "longer to charge"? What is 1 Farad? Would it be ok to have a 2.5 volt supercapacitor? Says has extremely low ESR. I have a electronics book that has a TON of capacitors in it and nothings near teh voltage yall are talkin about...there are some 10 and 16 volts but they are low except for that one that is 10,000. The only 4700uf is 25 volt
Old 03-22-2004, 10:58 AM
  #28
Tres's Avatar
1 Farad = 1,000,000uF
Tres is offline
Old 03-22-2004, 11:32 AM
  #29
What is ESR?
What is a good low ESR for a 10,000uF capacitor?
ratcar is offline
Old 03-22-2004, 01:32 PM
  #30
Brandon R's Avatar
ok would it be ok for the capacitor to be 2.5 volt?
