Old 01-12-2010, 01:59 AM   #1
Trader Rating: 4 (83%+)
Default Aluminum Foil On Receiver/Radio
I have a Futaba 2PL basic radio controller with the receiver that came with it. I want to know if putting the tin foil on the radio controller antenna and receiver tips would help the reception be clearer or make it better in general. Or is it insignificant and doesn't help.?
DriftWoof is offline   Reply With Quote
Old 01-12-2010, 02:17 AM   #2
i noticed when i wrap the receiver box in foil, less glitches. works for me.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 01-12-2010, 01:18 PM   #3
Did you put allot on the tip of the receiver antenna and completely cover the receiver box? Also did you use any on the tip of your radio antenna?
Old 01-12-2010, 01:26 PM   #4
It may or may not...but so long as your equipment is setup properly it won't be needed.
Old 01-12-2010, 01:28 PM   #5
HB Moose's Avatar
I've heard that aluminum foil hats help too.
Bruce "Moose" Riedinger
HB Moose is offline   Reply With Quote
Old 01-12-2010, 01:58 PM   #6
They do, thats why the emporer of Rome war them:
Thanks for the responses, I have seen people do it ad wondered it it actually helped.
Old 01-12-2010, 02:14 PM   #7
not on the receiver antenna. just on the receiver box and sometimes on the servo and esc wires that plug into the receiver. i use foil tape.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
Old 01-12-2010, 05:19 PM   #8
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Yokomo made a small kit for wrapping receivers, came with RF tape, and foil tape if I remember right, not sure if it's still sold or not now that most have gone to 2.4. I used to buy it at Speedtech.
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Severe Radio Glitching Help (Tamiya TA05) AWK Electric On-Road 37 06-11-2007 12:13 PM
