Old 01-11-2010, 06:13 AM   #16
theisgroup's Avatar
Originally Posted by niznai View Post
Quick question for Tekin team
Is v 4.0 all I need to download to be up to date? I mean is it the same thing as v203 (or whatever is the latest version?)
Thank you very much.
version 4 is the hotwire software and v203 is the firmware for the speedo. and the combination is vegas 2.0
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 01-11-2010, 06:17 AM   #17
Skitee's Avatar
Yes V203 is contained within HotWire Version 4
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 01-11-2010, 06:35 AM   #18
Originally Posted by theisgroup View Post
does this happen without the data logger?
Yes, that's why I put the logger in.
Ran a similar set-up in 17.5 and didn't have any major issues. Switched to 13.5 with the same timing and had a lot of issues.
Looks like the high wind motors (and single cell) can take the high timing but the lower wind (13.5-10.5) motors need to have less timing in order to work properly. For me, 40 boost with the 13.5's that I ran was too much.
Fred_B is offline   Reply With Quote
Old 01-11-2010, 06:47 AM   #19
theisgroup's Avatar
i have seen this with 1 cell with guys running boosters, but I don't run much 2cell so not sure what is happening. I can tell you in 1 cell with 17.5 and 13.5 I can run up to 50 boost, 10 can timing, and 10 turbo without any cogging, but I make sure the turbo delay is pretty long to allow the motor to spool before adding the turbo in. I have not seen this happen to any of our 13.5 rubber tc guys. almost all our sedan folks are running tekins. and I am sure at least a few have over 40 timing boost.
yang lai
Old 01-12-2010, 03:31 PM   #20
irgo's Avatar
Default Cogging
Sensoreless is actually not a realy sensoreless
it sense through back emf from phase wires
so it will cause cogging
there is nothing about turbo or low Turn for a cogging problems
the only thing causing cogging is bad sensored wired,
if you try Novak logger, i had expirience if sensored wired incorrectly pluged or disconnected, it will show it's max rpm instead 0 rpm.
So try to replace your sensor wired.
Other than that. Try to use Sensoreless ( without sensored wired ) run test on load.
then compare it with sensored wired pluged.
if sensoreless run test runs better than when you are using sensored wired, it would be your sensored wired mistake.
Quark Force
irgo is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Team Tekin New Speedos Drew_Cat Radio and Electronics 1521 10-06-2012 12:35 AM
Hobbywing new burssless ESC testing autostyle Electric On-Road 73 03-02-2009 06:55 AM
