Old 01-08-2010, 03:28 PM   #1
drive2survive's Avatar
Trader Rating: 23 (100%+)
Default BRUSHLESS/BRUSHED EQUIVILENT?
looking for a equivilent chart that converts brushless/brushed motors...re the size of each, example>>>> what brushed motor would be equal to a BL and visaversa
"OLD MUSICIANS NEVER DIE, THEY JUST DE-COMPOSE"
drive2survive is offline   Reply With Quote
Old 01-08-2010, 03:50 PM   #2
Trader Rating: 38 (100%+)
Too hard to gauge now with timing advances with brushless and the fact they don't run together anymore.
It use to be 17.5 was a 27T but it might be a 19T or better now.
or8ital is offline   Reply With Quote
Old 01-08-2010, 03:59 PM   #3
Rick Hohwart's Avatar
With brushed just about extinct in competition, there is no longer a need for equivalency charts. I doubt you will find anything up to date.
Rick Hohwart is offline   Reply With Quote
Old 01-08-2010, 06:47 PM   #4
greenracing's Avatar
If I'm not mistaken, from BL to brushed you multiply the number of the BL motor by 1.73. (square root of 3) why 1.73? all BL motors are 3 phase motors hence the square root of 3.
BLTx1.73=BRT
Example= 13.5 X 1.73 = 23.355 (now you know why the 19T motors are more powerful if conditions are equal)
this is a raw conversion, remember that performance wise, you have to add voltage, timing ect ect.
Hope this helps
AE RC8.2, OS Speed XZ-B
TLR 8ight T 3.0, Clockwork Modified RB F11
greenracing is offline   Reply With Quote
Old 01-08-2010, 06:56 PM   #5
wingracer's Avatar
Trader Rating: 24 (100%+)
BLTx1.73=BRT
Hope this helps
Yeah that used to be pretty accurate but the latest updates have brushless motors running like the next fastest motor. 13.5 can smoke a 19t now I think.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 01-08-2010, 07:09 PM   #6
Yes you are 100% right!!
For me this conversion helps if i was in a hiatus from to say...3 or 4 years and back then, i run my 4x4 with a 10 turn motor and now that I'm back i do not have a clue what BL motor is in the ballpark of my 10 T brushed motor. With the formula i can seek a BL motor close to that 10 T brushed and not making the mistake that if i see a 10.5 BL, i assumed that it is a 10T equivalent brushed motor.
Old 01-09-2010, 06:41 AM   #7
heretic's Avatar
Yes. And you don't even need timing advance to do that.
heretic is offline   Reply With Quote
Old 01-09-2010, 10:17 AM   #8
The problem is there are no equivalents. Even when we tried running brushed and brushless together there was always debate.
Think of it this way, how can you say a particular brushless motor is the equivalent of this brushed motor, when the gearing between the two has to be drastically different?
jiml is offline   Reply With Quote
Old 08-26-2010, 09:41 PM   #9
M3Armand's Avatar
BLTx1.73=BRT
Hope this helps
That doesn't seem right. A 13.5 BL seems much much faster than a 23T brushed motor regardless of timing!
M3Armand is offline   Reply With Quote
Old 08-26-2010, 09:52 PM   #10
skypilot's Avatar
Trader Rating: 14 (100%+)
I think it started out with the 13.5 being said to the 27t equal
semi retired..
skypilot is offline   Reply With Quote
Old 08-27-2010, 04:46 AM   #11
irgo's Avatar
Default Why not Both
have been Run Brushless since 2003
Brushless (positives) is incomparable to Brushed by:
Efficiency 70-90%
Very Low Maintenance (no Brushed Change) (but bearings).
Better buy another Motor rather buying Brushed for more experience.
Software Legal Timing (less Wrenching).
Sensored (abilities for a very low speed drive ability)
Sensoreless ( Dares to play with mud ).
Can run Newest Speed Passion Cirtix Motor Slotless Sensored Brushless.
Brushless (negatives)
Required 3 Wires for 3 Phase Minimum.
Require Sensor Wires for Sensored Motor.
sensoreless Cogging.
Brushed (positives)
we can run more than one motor at once on one controller.
Memory/cogitation
because any Brushless Controller is capable to run Brushed Motor,
very happy not to forget Brushed,
Better understanding for education.
What ever i like both!
Cheers :
Quark Force
irgo is offline   Reply With Quote
HPI Super Electric RS4's W/Brushless system Silver Cup Oval, Larger Scales and More 671 05-15-2017 11:28 AM
eZRUN brushless system 32819toon Electric On-Road 1032 08-05-2013 05:54 AM
Fast brushed off-road motor Hoops Electric Off-Road 13 12-28-2009 02:45 PM
New Novak Stock Brushless syndr0me Electric On-Road 524 03-13-2007 04:33 PM
