Old 03-16-2004, 10:22 AM   #1
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
Default Foam Tire Selection for TC3, questions
Just got a couple of questions on foam tire selection:
1. I noticed there are compounds in green and blue that don't seem to be used much and hence are cheaper. Are these compounds just not good for racing at all?
2. What is the maximum size tire you can run on the front and rear of the TC3? I have heard that some tires are too wide to work properly.
3. Where is the cheapest place to order foam tires? Post the site and the price.
4. I am currently looking at a set of Tans and Cyans for my TC3 as I heard that our track isn't as grippy as the old track so purples and plaids are alittle too hard. Any thoughts on thos combo?
I think thats about it . Thanks!
Old 03-16-2004, 11:21 AM   #2
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
You could also try Purple front, pink rear combo.
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 03-16-2004, 11:25 AM   #3
Tres's Avatar
From the Trinity site..
Standard Foam (normal wear) (carpet or asphalt)
- Orange (good for low-bite on-road tracks or an oval right front.) 54-55 shore
- Double Blue (good for on-road fronts on low bite tracks, outdoors) 50-51 shore
- Blue (good on-road front outdoors or harder rear on high bite tracks) 39-40 shore
- Green (good for on-road rears outdoors or indoors on low bite tracks) 29-30 shore
Exotic Foam (normal wear) (typically carpet only)
- Black (good for very high bite carpet tracks) 36-37 shore
- Gray (excellent for on-road rears on carpet) 29-30 shore
- White (good rear for lower bite carpet tracks) 25-26 shore
Natural Rubber (low wear) (carpet or asphalt)
- Red (good for fronts mostly outdoor nitro touring or right front oval) 45 shore
- Dbl Purple™ (good for fronts mostly carpet touring or nitro touring) 42-45 shore
- Lime (good touring front or hard rear) 42 shore
- Purple (good for on-road fronts any surface, touring front and rear any surface) 40 shore
- Tan (good touring rear or soft front) 37 shore
- Magenta (good for on-road fronts, touring rears all surfaces) 35 shore
- Brown (good touring rear tires for all surfaces) 32 shore
- Pink (excellent for rear on-road asphalt, carpet oval rear tire) 30 shore
- Platinum (good for on-road asphalt in low bite conditions) 25 shore
Combo Tires (low wear) (carpet or asphalt)
Plaid™ - Purple/Orange (Excellent for carpet touring front tire on high bite tracks)
Cyan - Magenta/Purple (Good for carpet touring front tire on low bite tracks)
Granite - Gray/Black (Good for high bite carpet tracks
Tre's
www.tnt-fx.com
Old 03-16-2004, 01:51 PM   #4
Tech Legend
Cain's Avatar
Thanks for the info. I picked up a set of cyan and tan tires . They should be in hopefully by the end of the week.
I probably will be running some used foams, purples and plaids tommorrow, will see how it goes.
Old 03-16-2004, 02:43 PM   #5
lowline's Avatar
Default tc3
dbl. pink rear,dbl. pink orangr frt. this combo rocks
lowline is offline   Reply With Quote
Old 03-16-2004, 03:04 PM   #6
Send a message via AIM to True R/C Racing
Default Re: tc3
isnt that for Mod?.... for Stock//19turn Plaids-front Purple-Rear
True R/C Racing is offline   Reply With Quote
Old 03-16-2004, 03:17 PM   #7
fatdoggy's Avatar
Default Re: Re: tc3
It depends on the track and setup. People use it in stock at my local track and it seems to work fine.
fatdoggy is offline   Reply With Quote
Old 03-16-2004, 03:30 PM   #8
lowline's Avatar
Default tc3
Not necessarily @ mikes in dallas work great stock or mod check it out www.mikeshobbyshop.com.
Old 03-16-2004, 06:52 PM   #9
Tech Legend
Cain's Avatar
I agree alot of it is track dependent. Plus, don't forget depends on your driving style too!
Old 03-16-2004, 07:10 PM   #10
Mike Haynes's Avatar
Plaid and purple tires seem to be the best general combo, they have worked great for me on a variety of tracks.
To keep the balence of front rear traction the plaid purple combo has, use cyan and magenta. It will be better for lower traction or tight tracks.
Note--I run only TRC tires.
For the tc3, up to 30mm rims can be used, but if you use the outer shock mounting hole on the arm, then you will hit the shock eyelet if the front wheels are turned all the way.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Foam Selection? part-time racer Electric On-Road 5 12-04-2007 01:22 PM
Foam Tire Questions SlamMan Nitro On-Road 39 05-04-2007 04:54 PM
Lipo selection questions Aluma Electric On-Road 4 05-01-2006 10:41 AM
Foam tire questions drx Electric On-Road 4 02-20-2005 09:15 AM
Tire Selection donoman Electric On-Road 8 08-23-2004 06:52 AM
